Results 1 to 15 of 15
Thread: VY SS Headlight Lense Replacement
    VY Clubsport R8
    Sep 2010
    Default VY SS Headlight Lense Replacement
    I recently hit my car and broke my headlight tabs, I bought a pair of used genuine but the lense is all scratched deeply.
    I'm thinking of swapping my lenses over, is it a easy process or not worth it?
    MEESEN's Avatar
    MEESEN is offline V8 6 Speed coming :D
    '03 VY
    Jun 2010
    Is say its not worthwhile, its sealed pretty damn tightly and you'd probably crack the lens tabs if you tried
    Ive heard of people using wet and dry sand paper on their headlights lens', probaby your best bet
    VY Clubsport R8
    Sep 2010
    Yeh I was thinking of rubbing it back with 1200 paper and buffing it but I don't think it will remove deep scratches. Any one else have any thoughts???
    vy executive s2
    Jul 2008
    If you search for a how to on painting your headlights. Gives you a step by step in removing the lense. It's not easy but can be done.
    CAM'S VY PHREDDIFIED AND LEATHERED!
    http://forums.justcommodores.com.au/...w-leather.html
    VY Clubsport R8
    Sep 2010
    kcpwns's Avatar
    kcpwns is offline Kicker - Livin' Loud :)
    VY V6 Equipe
    Jan 2010
    Shepparton
    I pulled both my headlights apart to install projectors. Not easy but do able. Easier with an extra pair of hands
    Quote Originally Posted by some_guy View Post
    This posts stupidity makes baby jesus cry.
    My Ride
    currently retrofitting projector headlights
    02 VY SS
    Apr 2010
    I bought a set of non geniune ones off ebay, guy lives less then 1 k from me, picked up cost me $110 for both lights and they look fantastic as good as genuine, kept my old ones just in case but so far so good
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    when I asked about fitting angle eyes I was told to pull apart the headlight, you place it in a warm to moderate oven and this makes the glue soft and sticky.
    But keep an eye on it as they will warp or melt if left too long.
    Then you pull the halfs apart.
    They didn't say whether to replace the glue for putting back together.
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
    vy executive s2
    Jul 2008
    Quote Originally Posted by Surfwagon View Post
    The guide I've seen is once your done put it back in the oven to soften the existing glue an put back together.
    VY Clubsport R8
    Sep 2010
    Yeah i might try putting it in the oven, how long you guys recommend and at what temp??? After i pull them apart i can get rid of the glue and re-seal up again with urethane.
    Aftermarket ones are all over eBay, i just always thought it may cause problems like larger gaps in a few areas and tabs not lining up properly, i guess everyone makes them differently.
    kcpwns's Avatar
    VY V6 Equipe
    Jan 2010
    Shepparton
    Used a hair dryer...and just reheated when sticking it back together.
    My Ride
    MEESEN's Avatar
    '03 VY
    Jun 2010
    kcpwns's Avatar
    VY V6 Equipe
    Jan 2010
    Shepparton
    eBay. Well I got onto a seller through eBay
    My Ride
    MEESEN's Avatar
    '03 VY
    Jun 2010
    Would ya mind sharing a link?
    I've got a spare set of headlights and wouldn't mind doing the same thing... U should do a write up
  15. #15
    VY Clubsport R8
    Sep 2010
    I stumbled across these on eBay
    Holden Commodore VY LED DRL Black Headlights Euro Style | eBay
    I wouldn't mind these actually if they fit up nice and straight, anyone got these headlights?
  1. VY Headlight replacement. full casing etc...
    By cliffo in forum VY Holden Commodore (2002 - 2004)
    Last Post: 29-12-2010, 11:29 AM
  2. worn headlight lense
    By THOMMO90 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 23-03-2010, 08:20 PM
  3. ECU/BCM replacement, and remote key replacement/ignition replacement
    By skunks.monks in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-03-2010, 09:08 PM
  4. [NSW] FS: Canon 400D Twin Lense Pack
    By FstStig in forum Parts And Other Items For Sale
    Last Post: 01-10-2009, 04:13 PM
  5. where to get a VP SS Fog lamp Lense?
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-11-2007, 09:02 AM
