The boot on my VY is stuck closed. Both the remote key button and glovebox button will not open it. I can hear the motor in the back trying to release the latch, but it's still closed.
I have managed to open it by crawling into the boot through the reclined backseat and pulling on the emergency cable (incase you get trapped inside). But this is not a long term solution.
Any help appreciated.
Thanks
does it open if you lift the boot/put some pressure on it while pressing the unlock button??
@ (im not inside)
The boot lock actuation rod would have broken.
Go to Holden/wherever and tell them what is happening and that you need the boot actuator rod and they will sell you the right part. It's roughly 3 inches long and connects the boot lock to the actuator. Which is why remote release wont work
Originally Posted by Reaper:
Originally Posted by Jecs:
I found it here, thanks. VX Boot Lock Broken - How fix it.
Thread title made me lose my shit!!!
Originally Posted by garth
hmmm i have a similar issue i guess, But its not the rod thats broken.
I Find if the boot is closed a little too hard, the boot will not release and the motor wont pull the lock when you press the button.
So this ends up with using the emergency release behind the seats.
If the boot is closed very gently its fine.
Any ideas ?
As per above, the actuator rod will be broken, its like coathanger wire bend into a rod about 3 inches, it will be obvious once you take the boot liner off, I actually replaced mine with coathanger wire as it was stronger, just model it exactly on the broken one, mine was broken at the end where it bends around at 180 degrees. I think when you take it to holden to be fixed they try to tell you to replace the whole thing including the motor bit, way dearer than just the wire.
