Results 1 to 7 of 7
Thread: vy headlights need advice on cleaning the crap off
    VY Lumina
    Jun 2011
    adelaide
    Default vy headlights need advice on cleaning the crap off
    seems to be some hard plastic type stuff
    any ideas?
    Oct 2004
    I use a Electric Buffer with a Lambswool Pad with some fine grade cutting polish
    there are kits you can buy from autobarn or supercheap which will clean up the headlights for you ive never used them but i hear they work
    failing you have these just try some polish and a rag and a 1/2L of elbow grease
    VT
    May 2010
    Wollongong
    VY Lumina
    Jun 2011
    adelaide
    WH Stato
    Jul 2004
    Moorabbin
    There's no long term solution to this problem, what you're seeing is a breakdown of the polycarbonate lens (basically the clear coat peeling) for the best result remove the headlights, rub the lenses with 1000-1200 wet sandpaper & high speed polish (as has been mentioned) & give them a smothering of baby oil every few months (basically sunscreen).
    Use caution though, trying to get oil from a baby tends to upset the parents.......
    VY Lumina
    Jun 2011
    adelaide
    lol
    sounds like it would just be easier to buy new headlights... ss ones maybe... to go with the ss bumper im putting on this weekend
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    It is much much easier to buy new headlights. What has happened is the UV coating on the plastic has worn away, and the plastic underneath has oxidized. You can sand and repolish the plastic but you will need to continually reapply a UV protectant (such as 303 Aerospace Protectant) or they will just end up like that again.
    Aftermarket reproduction headlights are reasonably cheap. The weather seals and mounting lugs on the aftermarket headlights are sometimes a poorer fit then the genuine headlights - other then that you can't tell the difference.
  1. VT headlights hazy and need cleaning - help!
    By lordmuz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-03-2010, 03:16 PM
  2. Cleaning Vs headlights
    By M01ST in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-07-2009, 12:45 PM
  3. im really surprised about cleaning headlights
    By callum_88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-05-2009, 12:13 PM
  4. My VN and all the crap advice!!!
    By misslisa in forum VN - VP - VG - VQ
    Last Post: 17-03-2006, 05:41 PM
