Results 1 to 17 of 17
Thread: ticking noise
    V.Y SS Commodore 5.7 6 speed manual Cammed
    Aug 2011
    Whyalla S.A
    Default ticking noise
    hey all
    i got a vy ss with a cam and i have a ticking noise when its warmed up but its not constant just every now and again.
    any suggestions wat it could be?
    commodore
    Aug 2009
    australia
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    As above. Good chance its your lifters. This is often worsened with an aftermarked cam if it has an agressive profile. What type and grade of oil are you running? Running a different reputable brand or grade can often help this since its only intermittent.
    Z' Series HSV 297KW 6lt LS2 Conversion For Sale!
    PM Me For Details
    Aug 2011
    Whyalla S.A
    Aug 2011
    Whyalla S.A
    i had a look under the car and noticed that i stock cat converters on it could it possibly be this?
    Aug 2011
    Whyalla S.A
    well i thought i would make a update the noise is still there and its getting worse, i put this free up noisy tapet/lifter and it hasnt helped so i dunno wat i could be.
    would a diagnostic computer find a fault or?
    1998 Mercedes Vito 113
    Oct 2009
    S.E VIC
    My cars got a tick in the far left cylinder aswell haha. I suspected a lifter aswell, even though i got all of mine replaced with the cam install.
    Check your oil pressures hot/cold in conjunction with the Holden specs
    Check your oils etc.
    If that's all good, (this is sourced from Steve @ Mace), he said you can cheat by putting a higher ratio rockers on as they put more force onto the lifter, which (in short description) stops the ticking.
    ^ I'm not too sure on that stuff though, you're better off asking Steve about that - So don't take my word on it.
    I know this might sound weird, but it could be your injectors too.
    edit: How many K's has your car done? If it's over 100,000 I thought running higher than 5/30 was more recommended. I ran a lighter oil in mine by accident, and it definitely made a loud ticking noise from the injectors. - Which got louder.
    Quote Originally Posted by perkoracin
    it like u pull at to a red light and they go o its that fag from just Commodores and it like u go tohe drags and ur car runs a like a 9 sec run as a eg and theres run a low 14 um i would Lol so hard like Epicly and then call them The Internet Mouthers and no go Lol thats a eg they might have Fast as rides 2 but may not sound as a Nice small block chevy with a Supercharger on it lol.
    Click here for my old VY Commodore!
    Mar 2008
    Just to elaborate on what DevilDRake's mentioned, you can also linish down the rocker pedestals or run slightly longer pushrods. This will put more lifter crush on the lifter, often curing a lazy lifter. I suppose it might be something to consider prior to changing lifters
    Cheers,
    Steve
    MACE Engineering Group
    www.maceengineering.com.au
    Powering Australia's best Commodores
    Find us on Facebook:
    MaceEngineering
    CAMMED VY SS Series 2 M6
    Jan 2009
    Whyalla S.A
    VY S Pack Commodore Ute
    Sep 2011
    S.A
    my ute does this i reckon its the hydraulic lifters it goes away after the oil pressure bulids up well 4 me anyway
    vx custom 600RR
    Oct 2010
    it's the PVC
    i bet it only happens when the engine is slowing down
    if it were an engine problem you'd hear it all the time
    Mar 2008
    Quote Originally Posted by Macka21 View Post
    My car has only got 95xxx on it
    Ah a cam, then you may need longer pushrods depending on the cam base circle (reduction in size)
    MaceEngineering
    Jan 2009
    Whyalla S.A
    Oct 2009
    S.E VIC
    Quote Originally Posted by oska View Post
    it's the PVC
    Haha like mine, i hear it.. all the time.. With music and everything down obviously.
  15. #15
    Jan 2009
    Whyalla S.A
  16. #16
    Aug 2011
    Whyalla S.A
    well another update and its worse then i thought i is a broken valve spring and also while i was in the engine bay with my mechanic there was a another diagnosis... my water pump is on the way out.
    so i shall be calling the delaership i bought the car from and see if they are gonna fix the problems. i will keep updating on progression
  17. #17
    Aug 2011
    Whyalla S.A
    well today the guy from the car dealership and he isnt going to pay for the valve spring replacement, but he will replace the water pump.
    i wasnt happy with the outcome so i had a heated conversation with him and after all of him spinning some crap i got a outcome of him putting $200 towards the new performance springs
  1. ticking noise in L67....
    By emmtee83 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-11-2009, 05:45 PM
  2. ticking noise
    By trentvy in forum VY Holden Commodore (2002 - 2004)
    Last Post: 01-09-2009, 05:26 PM
  3. Ticking Noise
    By chitchat2000 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-05-2009, 10:35 PM
  4. ticking noise..
    By matt_gotigers in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-11-2007, 09:44 PM
  5. ticking noise
    By krisjanik in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-09-2006, 06:44 PM
