Results 1 to 7 of 7
Thread: missfiring
    supercharged vy series 2 2003
    Sep 2011
    swan hill
    Default missfiring
    Hey ppl my car is still missing on all 6 cylinders iv put in new plugs leads coil packs had it pressure tested ect cleaned out the throttle body put new vaccum hoses on it checked the fuel pressure and thats fine yet it still does it does anyone no what it could be ?
    vyseriesII's Avatar
    vyseriesII is offline The V6 is MACEd
    2004 Vy S Series II
    May 2011
    Are you 100% sure it's a missfire and not some vacuum leak or something making it sound rough? Make sure the hoses of the throttle body go into where they should. One at the back of the motor and one into the manifold. Also, maybe dirty/clogged injectors.
    Sep 2011
    swan hill
    Im 100% sure its a missfire iv also double checked those hose on the throttle body and the ones at the back of the motor with no result ? Could possibly be injecters that about the only thing I haven't done but if it was missing on all 6 wouldnt the car just not run ?
    VY S Series 2
    May 2010
    VY Commodore Series 2 S 2003
    Sep 2011
    Australia NSW
    i had recent problems like this in my VY and it was ratss to be the cause and if i was you i would check that all the injectors are in place and that none of the wires are damaged or cut and to go over your whole care and check that no wires or hoses are out of place.
    Sep 2011
    swan hill
    After unclipping the maf and starting the car my computer comes up with tcu error is that normal ?
    Sep 2011
    swan hill
    Anyone ? No one tryed it ?
  1. missfiring
    By tacotacoburito in forum VY Holden Commodore (2002 - 2004)
    Last Post: 08-09-2011, 07:25 PM
  2. Vs missfiring?
    By wildeagle44 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-09-2010, 04:02 PM
  3. Vl still missfiring?
    By Jordo2 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-07-2010, 06:36 PM
  4. Vl Missfiring under load.
    Last Post: 23-06-2010, 11:11 PM
  5. Vn Missfiring??
    By VHSLX3300 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-11-2006, 09:53 PM
