Results 1 to 20 of 20
Thread: Vy ute performance upgrades
    Vy spack v6
    Sep 2011
    Default Vy ute performance upgrades
    Iv got a vy v6 ute,
    Current mods are
    Dual cat back exhaust
    Pacemaker headders
    K&n pod filter
    A little head work- matched &ported, springs, rods, retainers etc
    Cam and tune
    Dynod at 205rwhp
    I have manifold and plenum spaceRs on the way with 69mm throttle body
    How much difference will this make?
    Iv also got 3:9 diff gears coming too..
    Wat other mods could i consider b4 puttin a blower on..
    Would i see gains out of msd coils and leads? Or even better than stock plugs?
    Wld a cai make a difference?
    All suggestions wld be appreciated
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    Search and you will get all the answers you want. OT: MSD coils waste of time. Changing spark plugs to anything but factory also a waste of time.
    Vy spack v6
    Sep 2011
    Im from perth n no1 wants to know bout a v6 over here, im running out of obvious ideas as the cam has too much lift
    For roller rockers
    Jezza's Avatar
    Jezza is offline Ecotec Just Kicked In!
    VYII Acclaim
    Apr 2009
    South Australia
    check out mace in the sponser section as im sure they do a cam to suit roller rockers
    Quote Originally Posted by SHEENY05 View Post
    I have always thought a quick six will turn more heads cause if you gear a V8 you sorta expect it to go hard
    Vy spack v6
    Sep 2011
    Iv got a cam, its just the lift of it is too high for roller rockers, so i wnt see any gains.. Will a cai give me any gains?
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    not sure on gains but it will definatly breathe better - do this along with your spacers and throttle
    Vy spack v6
    Sep 2011
    Wat ratio will suit? I dnt know anything bout rockers.. Im hoping to see 230rwhp naturall aspirated
    Munz's Avatar
    Jan 2011
    Brisbane NTH
    I was talkin CAI
    Leave your rockers alone unless you know exactly whats goin on with that cam ie do you know lift specs/ at what stage would the extra lift become a PTV issue
    Vy spack v6
    Sep 2011
    this is my cam..
    Duration @0.050 222/224
    Lobe lifts: 337"/327"
    Valve lift with 1.60:1 rocker arm 539"/523
    112 lsa
    108 intake centreline
    Drawnnite's Avatar
    Drawnnite is online now Obviously Unsensible
    2000 Vs Ute
    Sep 2010
    you could always consider stroking it. COME racing have a kit for it, but the overall cost may not exactly be cheap.
    how about we make the pedals out of sticky rubber and the shoes with steel spikes. at least my shins would like that
    Quote Originally Posted by Jonesy484 View Post
    yeah i wondered the same thing when i was 4 when i grabbed the chrome exhaust of my dads rx7
    Quote Originally Posted by DM 55 WA View Post
    did you think it was a milo tin?
    Vy spack v6
    Sep 2011
    How much more power would that give me? I wanna get asmuch as i can out of it then maybe supercharge? Wat does stroking involve?
    Drawnnite's Avatar
    2000 Vs Ute
    Sep 2010
    pretty much stroking it will require a whole engine rebuild if done properly. and you can get them for boost applications
    will contain pistons, new crankshaft, and so forth.
    will produce alot more torque, and a little bit more power. while taking the engine out to approx 4.2L (from 3.8L)
    approximate amounts of power are 230Kw's but i believer that is at the fly and not the wheels, but i may be wrong.
    however if you are going to charge it, i would say get this done at the same time, so the rebuild and everything is in one hit.
    but mind you, a stroker kit is like 2500-4000 and then a few extra $'s to get it all rebuild and machined etc
    it may also require a new camshaft to match so that everything is intime and working properly. so it can be a very expensive exercise.
    the stroker kit works by causing a bigger displacement by making the travel of the piston longer.
    and if you really wanted to go over the top, you could have the cyylinders bored out for bigger piston heads.
    although i have no idea how that would go in an ecotec.
    oh and youll probably get alot of answers such as, dont waste your money on a v6, buy a v8 instead.
    just get ready for them =P
    Vy spack v6
    Sep 2011
    So its like a recond kinda thing but better ofcourse? Yeah i know bout the comments lol even the missus bugs me bout me.. Shes just jealous cos i beat her au xr8 be a good experiment
    Munz's Avatar
    Jan 2011
    Brisbane NTH
  15. #15
    Vy spack v6
    Sep 2011
    Yeah im not sure bout that either, been told it could work.. But hav to see how i go
  16. #16
    vyseriesII's Avatar
    vyseriesII is online now The V6 is MACEd
    2004 Vy S Series II
    May 2011
  17. #17
    Munz's Avatar
    Jan 2011
    Brisbane NTH
    Usually around $50-100 you just have to look in your local paper under 'outcalls'
  18. #18
    Drawnnite's Avatar
    2000 Vs Ute
    Sep 2010
    if your going to Charge it and also Stroke it. i would say get it done in one hit though. dont want to go through 3 cams, 3 tunes, 3 this 3 that etc.
    just an idea.
    and MUNZ has a dirty mind =P
  19. #19
    Vy spack v6
    Sep 2011
    I wanna see how it goes naturally aspirated first.. Heads are pretty much stock and dnt have an air intake yet, so iv
    Got a fair bit to gain yet..
    Wat chargers are better? Those top mounts or centrefugal things lol
  20. #20
    2001 VU s
    May 2012
    naz
    do you notice a lot difference using the K&n pod filter? im looking at getting one just wondering if its worth it. cheers
  1. VY Performance Upgrades?
    By Neodude112320 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 06-06-2011, 09:58 PM
  2. performance upgrades?
    By DRed in forum V6 Development And Modification
    Last Post: 19-08-2010, 01:17 PM
  3. V6 performance upgrades
    By rex2229 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-10-2008, 03:41 PM
  4. Performance upgrades for my VT
    By VTS in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-05-2006, 08:46 AM
  5. VT Performance Upgrades...NEED HELP!
    By ducatis in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-04-2006, 07:40 PM
