Results 1 to 4 of 4
Thread: vy 2004 executive abs warning light when braking and draining battery
    2004 VY v6 commodore sedan
    Sep 2011
    caboolture, queensland
    Default vy 2004 executive abs warning light when braking and draining battery
    hi guys.
    my 2004 executive vy has started to show the abs warning light when braking, also every time i drive the car it drains the battery. I have checked the battery, alternator, and resistance in the terminals and all is fine. WHAT ELSE CAN IT BE.... Please help??
    vl
    Apr 2011
    brisbane
    VY II S V6 Supercharged and 911 Porsche 996 3.6
    May 2009
    VIC / NSW
    The engine has only 2 sources of power, the alternator and the battery. If the alternator is not supplying sufficient power, or is supplying no power, to the engine's electrical system then the battery will be discharged while driving the car. From what you have said, ie. the battery is draining when you operate the engine, I would conclude that either the alternator is faulty or there is a problem with the wiring connected to the alternator so there is zero or insufficient power being delivered by the alternator to the engine's electrical system. Hence the battery power is drawn to operate the car. I would suggest the most likely cause is a faulty alternator.
    I suspect/guess that the ABS warning which occurs when running the car, and then braking, might be connected to the power supply problem, particularly if this problem occurred at around the same time. The ABS needs sufficient power at all times to function. Fix the power supply issue first and re-check.
    VY S Pack Commodore Ute
    Sep 2011
    S.A
    maybe im not 100% but check the bushes in ur alternator if they r knackered this will happen. they r easy enough 2 check if u know wat ur looking 4
  1. Battery WARNING LIGHT
    By harvs01 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-02-2007, 07:13 AM
  2. Battery WARNING LIGHT
    Last Post: 09-01-2007, 07:53 AM
  3. Battery Warning Light Came On
    By mikemutlow in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-02-2006, 12:39 AM
  4. Battery Warning Light
    By Big Al in forum Electrical Wiring / Questions
    Last Post: 02-06-2005, 10:23 PM
  5. Battery Warning Light
    By arty in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-02-2004, 09:54 PM
