Results 1 to 12 of 12
Thread: VY Indicator
    03 VY Exec
    Feb 2011
    VIC
    Default VY Indicator
    hey guys,
    my Front right indicator, is stuffing up i have changed the globe and its still not working, the indicator is blinking fast which, means wiring fault or blown globe.
    Any Suggestions of what i can do.
    Thanks from,
    Schoey3
    Jezza's Avatar
    Jezza is offline Ecotec Just Kicked In!
    VYII Acclaim
    Apr 2009
    South Australia
    is the globe the correct watts and volts as the old one because if its less then that could cause it to flash fast
    Quote Originally Posted by SHEENY05 View Post
    I have always thought a quick six will turn more heads cause if you gear a V8 you sorta expect it to go hard
    VY Berlina
    May 2011
    Central Coast
    Check your ground that generally is the problem, also if that doesn't work try putting an led globe with a resistor on it. they would be the first things I look at
    03 VY Exec
    Feb 2011
    VIC
    nah i put a brand new globe in that was the exact same as the one that was in there.
    it will be a wiring fault does anyone know how i am able to fix that or where the front right indicator wires go so i can test them?
    s/charged v6 HR Holden, s/charged v6 EH Holden,
    Sep 2007
    do you have a towbar plug?? sometimes a loose wire in that causes the blinkers to go haywire, or a blown globe on the side that is flashing fast....
    03 VY Exec
    Feb 2011
    VIC
    D3CID3R's Avatar
    D3CID3R is offline Just Commodores NSW
    VY Commodore HBD
    Feb 2010
    South-West Sydney
    whack a multi meter on it.. if in the end its stuffed.. parallel of the headlight indicator circuit
    Quote Originally Posted by mischa View Post
    Me and Jack went down to the shops and got 3 tubs of vaso
    03 VY Exec
    Feb 2011
    VIC
    03 VY Exec
    Feb 2011
    VIC
    VY II S V6 Supercharged and 911 Porsche 996 3.6
    May 2009
    VIC / NSW
    Quote Originally Posted by schoey3 View Post
    What was the wattage of the new globe you installed?
    Killr6's Avatar
    Killr6 is offline on boost
    XR6T
    Sep 2010
    Hervey Bay QLD
    you can pick them up from supercheap.
    have you installed it all correctly? i had one i did not install properly and when i double checked and fixed it, it worked fine.
    Starin at the world through my rearview
    Go on baby scream to God, he can't hear you
    I can feel your heart beatin fast cause it's time to die
    Gettin high, watchin time fly
    VY II Calais
    Nov 2008
    also check the rear and side indicator and make sure they are fully functional, the whole side will flash faster if one of the bulbs is gone on the whole side
    VY II Calais Bog stock V6 family mover. Sony head unit with bluetooth. Martini.
  1. vy indicator
    By schoey3 in forum Electrical Wiring / Questions
    Last Post: 03-10-2011, 04:34 PM
  2. VX indicator flasher relay unit help/LED indicator hyperflash
    By Denno in forum Electrical Wiring / Questions
    Last Post: 18-08-2011, 01:07 AM
  3. oil + indicator
    By RichVS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-03-2007, 06:35 AM
  4. VP - LHS indicator
    By s0sage in forum Parts And Other Items For Sale
    Last Post: 06-09-2005, 03:36 PM
  5. Indicator
    By Liddz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-04-2005, 04:52 PM
