Results 1 to 6 of 6
Thread: clunking/knocking noise
    03 VY V6 S2
    Oct 2005
    Default clunking/knocking noise
    Hi,
    I have a problem with my sedan which is driving me nuts.
    When i drive over uneven surfaces there is a knock sound. i cant tell which end it coming from.
    I can reliably make the noise occur if i: turn right into my driveway over the kerb, both front wheels go over no worries, as soon as the back drivers side wheel hits the kerb it knocks. everytime.
    I replaced the following since the noise started:
    All 4 shocks
    Front and rear swaybars and bushes.
    Front strut tops and bearings
    Front Z-Bar bushes (all 4)
    Both front swaybar links
    The only other thing im thinking is im pretty sure it may have started when i replaced the brake discs with DBAs and new pads. But ive checked them and they seem fine, cant see how it would be related..
    Any ideas??
    VY SS S2 Utility 2004
    Dec 2009
    Melbourne, Inner.
    hmm i would have said suspension problems myself, i can't really be sure tho, take it to a mechanic i suppose let them diagnose then just repair it urself
    livin' the low life.
    VY Acclaim / Toyota Aristo / VP Wagon
    Feb 2011
    s/charged v6 HR Holden, s/charged v6 EH Holden,
    Sep 2007
    my vy calais S/cV6 sedan used to knock a bit. It was the exhaust hitting on the body near the diff area , & also the rear muffler hitting on the upper surface where the rear rubber mounts are for it. If you have access to a hoist you can check the exhaust to body clearances.
    Also if you have a LSD diff they can clunk a bit on turns sometimes.
    good luck ,
    03 VY V6 S2
    Oct 2005
    actually that may be something to look at, because i replaced the extractors. thanks will look at that
    03 VY V6 S2
    Oct 2005
    found out what it was, i checked the exhaust to see it was hitting but it all cleared. So went went back to the front end and pulled the link pins out, which were pretty much brand new nolathane evolution ones with the two ball joints at either end. found one had the smallest bit of play in it, maybe .25mm. so i replaced with standard type super-pro pins. noise gone.
    nolathane = bad
  1. Strange Ratcheting/clunking noise similar to CV noise under front VE 2009
    By Velocity in forum VE Holden Commodore (2006 - ?)
    Last Post: 23-08-2011, 05:04 PM
  2. VT clunking noise
    By VT_2000 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-07-2010, 05:29 PM
  3. VR UTE Strut knocking clunking?
    By pezwa in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-12-2009, 08:45 AM
  4. Horrid knocking and clunking sound from rear.
    By MikesVT in forum VY Holden Commodore (2002 - 2004)
    Last Post: 10-09-2007, 11:01 PM
  5. Clunking Noise
    By blade_1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-04-2005, 12:57 AM
