Results 1 to 8 of 8
Thread: Sucking air after ignition turned off
    Vy Commodore
    Oct 2011
    Wingfield
    Talking Sucking air after ignition turned off
    Hi,
    I have an issue when i turn my ignition off there is a sucking sound from the air box that lasts for a couple
    of seconds post ignition turned off.
    took air box off and noise is coming from the flex pipe leading to the airbox
    Anyone that could suggest possible causes , i would appreciate the feedback as i haven't had this before.
    VY S Series 2
    May 2010
    The only thing i can think of is the bleed from the block to the throttlebody to get rid of crank case pressure... other than that i dont have a clue
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Entirely normal. As the ignition is switched off, there is no more bang, but the pistons still move due to inertia and create low pressure in the cylinders momentarily. It is the air rushing in that causes the noise. Nothing to worry about.
    Visit my Facebook page
    Vy Commodore
    Oct 2011
    Wingfield
    Default Sucking air after Ignition turned off
    Only problem is that the noise wasn't there prior to a couple of days ago and now it is noticible from inside the car
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Have you changed the air filter recently?
    Vy Commodore
    Oct 2011
    Wingfield
    No the filter has been there for a while.
    when i lifted the airbox lid the noise is somewhere from the throttlebody region back
    it almost sounds like a vacume leak.
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Could be the PCV solenoid at the back of the inlet manifold. Check the hose on the bottom of your throttle body.
    Vy Commodore
    Oct 2011
    Wingfield
    Hoses are ok may have to take to mechanics as nobody has heard this noise before
    Thanks
  1. Low pitched buzzing when ignition turned off
    By fourboys in forum VE Holden Commodore (2006 - ?)
    Last Post: 05-05-2012, 06:21 PM
  2. vs ignition stuck on while key is turned off
    By cozza9 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-01-2011, 02:39 PM
  3. lights on dash stay on and ignition is turned off
    By Alan22008 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-08-2009, 07:49 PM
  4. Replies: 5
    Last Post: 14-08-2008, 01:59 PM
  5. Pulled heater controls out - now a strange sucking noise/sucking from pipes?
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-01-2008, 04:01 PM
