Results 1 to 15 of 15
Thread: V6 Nearly stalls when started wont idle
    VY V6
    Jun 2011
    Armidale
    Default V6 Nearly stalls when started wont idle
    Im stuck! Its a VY II 3.8 with 40,000 KM. When i start car in morning fires up fine for 2 seconds then revs die down to nearly stall than ramp bak up to idle this process repeats for about 3-4min stalling sometimes, then idle settles but is still a little lumpy. When car firsts starts a little white smoke comes out exhaust for a few seconds.
    No Codes on tech 2 + cleaned AFM and TB. Fuel Pressure OK.
    Any help will be much apprecated.
    Car Has some mods.
    '04 VY II Calais
    Oct 2010
    Bayside, Victoria
    Have you checked oxygen sensors?
    If the oxygen sensor is sending the wrong signal to the PCM hunting could occur. One minute it's telling the PCM 'too lean, add more fuel' the next it's saying 'no, that was too rich, take fuel out'. The process can go on.
    Has your fuel consumption increased recently?
    VY V6
    Jun 2011
    Armidale
    Fuel Consumption has never been any good cause i have a Vortech V2 increasing that,
    As for the O2 sensors would that show up on the tech 2 as an error code?
    '04 VY II Calais
    Oct 2010
    Bayside, Victoria
    Not necessarily as they are still working, just not as they were designed. False readings from the O2 sensors don't classify as error codes, unless they're way out of plausibility.
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Check for any air leaks in the intake. The little hose on the bottom of the Throttle Body is a common problem. Symptoms are bad idle, but goes OK when given some throttle.
    Ronald Reagan (1986)
    VY SS S2 Utility 2004
    Dec 2009
    Melbourne, Inner.
    yeah as acarmody said check the vacume lines they can make the car idle incredibly poorly. short of that i don't know. good luck with the fix!
    livin' the low life.
    VY V6
    Jun 2011
    Armidale
    VY 3.8L Executive with Clubby Kit. Ex Marked Cop C
    Mar 2011
    Auckland, New Zealand
    I had a similar problem, had to replace the throttle cable because the plastic bit on the bracket had broke =P
    VX Berlina
    Apr 2007
    Quote Originally Posted by Antsmash View Post
    How does that affect the idle? The throttle cable should have no tension when idling.
    OP have you checked for error codes?
    Dansvr's Avatar
    Dansvr is offline my vy s2
    Vy series 2
    Mar 2011
    South east
    VX Berlina
    Apr 2007
    Quote Originally Posted by Dansvr View Post
    Mine is doing exactly the same thing!!! Help!!
    Have you checked for air leaks? Especially the hose underneath the Throttle Body?
    VY V6
    Jun 2011
    Armidale
    Have replace O2 sensors and checked for air leaks and the problem is still there. GRRR. Is there a better way to check for airleaks or is a can of WD-40 the best way?
    VY V6
    Jun 2011
    Armidale
    If you find what the problem is can you please let me know. Cheers
    VY V6
    Jun 2011
    Armidale
    VY V6
    Jun 2011
    Armidale
    Someone please help!!!
  1. VN stalls/wont start when warm
    By REWIRED in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-03-2011, 10:17 PM
  2. Vr stalls irratic idle abs??
    By vpwagon19 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-09-2010, 04:41 PM
  3. VT stalls When Left idle or stuck in traffic
    By orac in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-03-2008, 09:21 PM
  4. started then died.. now wont start.
    By ephect in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-03-2007, 09:14 PM
  5. nearly stalls crap idle
    By VSIIBerlinaL67 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-08-2005, 02:47 PM
