Results 1 to 9 of 9
Thread: Vx series 2 motor and box into vy series 2?
    Vr ss & vy v6 wagon
    Jan 2010
    Central Coast, NSW
    Default Vx series 2 motor and box into vy series 2?
    Hi,
    just wondering if theres any difference between a vx series 2 motor and box and a vy series 2 motor and box?
    can it be installed into a vy with no messing around having to change bits and pieces/adding or removing sensors etc?
    also can i use the vy computer with it?
    basically can i ,
    take old motor and box out of vy
    take engine loom off vy motor
    put loom on vx motor
    install vx motor and box into vy
    wet pants due to excitement that it was all straight forward and no messing around?
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Just use the VY harness and PCM as you've said. The rest is the same with no stuffing round.
    Z' Series HSV 297KW 6lt LS2 Conversion For Sale!
    PM Me For Details
    03 VY SS 5.7L M6
    Feb 2009
    Enoggera QLD
    Technically no you cant do this as its a no no to put an older engine into a newer car
    vx
    Aug 2011
    sa
    Quote Originally Posted by VY Rossi View Post
    true but your really talking maybe two years diffrence,, and really the computer would adjust the motor too meet the required updates,,,
    03 VY SS 5.7L M6
    Feb 2009
    Enoggera QLD
    Aug 2008
    NSW South Coast
    Depends on the states laws
    OP is in NSW and you CAN do it here, so long as all emissions control devices etc relevant to that model body are fitted. I've done a few v6 motor swaps like this.
    PM Me For Details
    vx
    Aug 2011
    sa
    like i said, its the same motor as the vz went alloytec?????hence why when you look at parts it goes vt vx vy,,not vz engine bits,,,,, the only change might be a senscer, but it will be okay too use
    Aug 2008
    NSW South Coast
    Quote Originally Posted by loopie View Post
    I think you've misunderstood what 'VY Rossi' meant... Yes there is bugger all changes between vs-vy ecotecs, however, some states will not allow a motor from an earlier model into a newer body, regardless of whether they're the same or not, based off the eng no. and the body model it was originally fitted to i.e. cannot fit a vt v6 into a vy v6 etc etc.
    The reference here is to legalities, not whether it is physically possible or not.
    PM Me For Details
  1. Series 1 motor with series 2 radiator, can it work?
    By DAVIDC in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-06-2012, 01:00 PM
  2. series 2 vq with series 2 vn motor, almost stalls between park and reverse and drive
    By sp001in in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-05-2011, 11:49 AM
  3. Series 2 engine parts onto a series 1 vn motor
    By v6vpute in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-10-2010, 05:19 PM
  4. Wiring Issue VN - After Series 2 motor put in Series 1 car
    By ghog1726 in forum Electrical Wiring / Questions
    Last Post: 18-04-2009, 03:30 PM
  5. Vr series 1 and series 2 is their a differance int the motor???
    By Raven_2656 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-09-2007, 02:26 AM
