Results 1 to 9 of 9
Thread: Sell or keep?
    Vy spack v6
    Sep 2011
    Default Sell or keep?
    This is my car.. My clutch is slipping, should i sell or put a hd cluch in??
    Opinions please
    my cammed vy v6 ute Dual fuel!
    Zeussy's Avatar
    Zeussy is offline SSM11K
    VY Acclaim S2, VH SLE
    Dec 2008
    Central Coast
    I think there's two questions there.
    Should I sell my car??
    Totally up to you. If you want to sell it because the clutch is gone, then
    My clutch is slipping, should i put a hd cluch in??
    I guess so, you've already said its slipping.
    I've heard the dual mass jobbies are useless and if you need to change it to just throw a solid flywheel in there.
    Heaps of places do them, so they should be pretty $$$ competitive.
    Vy spack v6
    Sep 2011
    I replaced the clutch a bit less than 2 yrs ago
    So the hd 1s piss over the dual mass fly wheel?
    What price roughly am i looking at for 1? Are the ebay 1s
    Anygood
    VX Exec M5
    Alien Invasion 2 Champion! Gyro Ball Champion!
    Apr 2010
    Melbourne, Bundoora
    If the VY's have a the getrag then it's definitely worth putting a hd clutch with a solid flywheel in.
    It's a lot cheaper than getting another dual mass (less that $1000 if you look around) but you will
    get a bit more trans noise coming through, like a slight shudder under load at low revs. As for the eBay
    items, I have no idea. Good luck with your choice.
    None of us are as cruel as All of us. - Anonymous
    Vy spack v6
    Sep 2011
    Yeah it is the 5speed manual.. Whats the difference between the dual mass and
    The solid?
    VX Exec M5
    Apr 2010
    Melbourne, Bundoora
    A dual mass flywheel is effectively two flywheels that transmit the drive through a number of springs which cushion the drive to the transmission.
    Which makes it softer on components, bringing less noise. The solid flywheel (which I have) is exactly that, a single plate solid flywheel. There is
    very little if any cushioning going on. And being a simpler piece of kit, it is cheaper to replace a clutch once a solid flywheel is in place because they
    can be resurfaced.
    So in summary
    Dual mass = Smooths out drivelines rough edges, but expensive to replace.
    Solid = A bit of extra driveline noise, the option of a heavy duty clutch and cheaper in the long run
    (especially if you're replacing the clutch every two years)
    That's from what I've been told and researched, I may have some of the details askew but that's how I understand it.
    Vy spack v6
    Sep 2011
    Thats awesome, thanks for that info! How noisey are u talking? Noticeable or only if u pay close attention to it
    VX Exec M5
    Apr 2010
    Melbourne, Bundoora
    Well in my case it's noticeable but not unbearable, it will vary from car to car depending on the health
    of your gearbox. With mine at low revs in gear (800-1300rpm) under load it makes a small chattering noise.
    It will never be as silent as the stock arrangement but it's a small price to pay for long term reliability.
    You might want to get your thrust bearing replaced at the same time as I'm told this can be the cause of
    most of the noise that you'll be hearing. Definitely worth the change, I wouldn't go back to a dual mass
    Vy spack v6
    Sep 2011
    Noworries.. Now the question is down to which clutch to choose lol Which clutch?
  1. To sell or not to sell???
    By veclubby in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-02-2007, 09:54 PM
  2. how much Can I sell my caR
    By Wong in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-01-2007, 02:14 AM
  3. To sell or not to sell (the house)
    By HDT_aero in forum The Pub
    Last Post: 20-01-2006, 12:48 PM
