Results 1 to 6 of 6
Thread: Which clutch?
    Vy spack v6
    Sep 2011
    Default Which clutch?
    Its for a vy v6.. Iv had 2 quotes.. Hd exedy clutch kit and solid flywheel$995
    Or xtreme hd clutch kit with solid fly $800
    Which is the stronger better quality clutch/ better brand
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Ive got the exedy hd in mine and love it. For a standard power output application i'd say either would be fine.
    Z' Series HSV 297KW 6lt LS2 Conversion For Sale!
    PM Me For Details
    Vy spack v6
    Sep 2011
    Its got a got more than stock.. Pretty sure its around 210kw at the fly.. Does it make a difference?
    Aug 2008
    NSW South Coast
    The exedy is certainly capable of holding much more than that. I would assume the xtreme to be pretty similar.
    PM Me For Details
    Vy spack v6
    Sep 2011
    OK, iv phoned round a bit and they reckon xtreme uses bits and pieces from exedy but the main diffrrence is the fly
    Wheel wieght.. Exedy =11kgs xtreme =7kgs
    What effect does that have on wear and tear? Both are chrome molly
    VX Exec M5
    Alien Invasion 2 Champion! Gyro Ball Champion!
    Apr 2010
    Melbourne, Bundoora
    Hello again, the wear and tear should be no different, it's all down to rotating mass.
    That is how much the flywheels weight will pull against itself when spinning.
    It's hard to explain so I'll put a link up but basically the heavier the fly, the more it takes to turn it.
    How a lightweight flywheel works
    But either way you'll end up with a strong setup. I have an exedy and haven't tried the xtreme
    so I can't really say which you should go for.
    None of us are as cruel as All of us. - Anonymous
  1. VX Clutch - How worn is this clutch..??
    By RvtRvx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-08-2011, 12:22 AM
  2. clutch is making a loud pop sound when i push the clutch in
    By giffo2010 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-06-2011, 04:37 PM
  3. [WA] VT-Z LS1 clutch master+slave cyl+reservoir + VX clutch pedal **SOLD**
    By savage1987 in forum Parts And Other Items For Sale
    Last Post: 23-05-2010, 11:22 PM
  4. Ls1 clutch
    By Robbo5390 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 02-05-2010, 03:09 PM
  5. sv6 clutch
    By tuffVE in forum VE Holden Commodore (2006 - ?)
    Last Post: 29-04-2010, 11:34 PM
