Results 1 to 17 of 17
Thread: Help me decide about my wing!
    VY 3.8L Executive with Clubby Kit. Ex Marked Cop C
    Mar 2011
    Auckland, New Zealand
    Default Help me decide about my wing!
    Hey guys.
    My VY has had an aftermarket body kit put on it. And I was looking at it the other day, and was thinking it would probably look better without the wing. There's four phillips screws holding it on, I thought that wasen't really enough and took them out. Still was on there quite well so I'm guessing they've used some kind of glue as well? Will the fishing wire trick work with this?
    Just want your guys much valued opinions on if you think it'll look better.
    Excuse the average photo =D
    Thanks.
    Help me decide about my wing!-rear.jpgHelp me decide about my wing!-189229_10150130247982017_538092016_6746920_1812595_n.jpg
    Edit : I know the Holden badge is a disgrace. That's on my list =P
    '94 VR Exec
    Feb 2010
    Wagga Wagga, NSW
    I think the spolier sort of suits that kit. I'm not sure how they are attached, if you're sure you got all the screws then I guess it could be glued down. I'd be more annoied by the little holes that you'd have to fill tbh. But if you can get it off, see what it looks like then decide.
    WTB: VR/VS S/SS Lower front bumper lip/spoiler
    Mar 2011
    Quote Originally Posted by F l a k View Post
    Yeah that's what I was going to do. But then it appeared to be glued down. I didn't try give it a good tug though =P
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    you might need to respray it if you remove the wing, generally the screw holes are fairly obvious
    01 VX Executive Series ll
    Sep 2011
    Bathurst
    If you don't like it without the spoiler or are worried about the screw holes maybe replace it with a SS spoiler similar shape so will suit bodykit but it's not so much of a coat hanger (not so high).
    And I would imagine the fish wire trick should work if it's been glued.
    A.MILMO
    Mar 2011
    Thanks for the advice guys. Nobodies really given there opinion if they think it'll look good gone though =P Wonder what kind of glue it is.
    VY2 SS
    May 2010
    Marrickville NSW
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    i recon take it off n see what it looks like,
    might look good, id prob try a smaller wing tho
    Quote Originally Posted by Rufys View Post
    yup! I think I might actually be gay
    Mar 2011
    Yeah the wings quite big. But it's a big car too =P Might have a look around see what around.
    VY II S V6 Supercharged and 911 Porsche 996 3.6
    May 2009
    VIC / NSW
    Quote Originally Posted by Antsmash View Post
    Yes it would look fine with no rear wing.
    However the problem is the holes that will be left and the possible damaged paint work in the contact area. You will need a boot lid repair and a complete 2 pack respray to get the boot lid back to original quality condition. The car looks fine with the spoiler (or without) so I would not worry about it.
    The issue with the appearance of the car is not the rear spoiler. It's those wheels. If you want to improve the appearance of the car I would spend money on changing the wheels and tyres and leave the spoiler alone.
    VY S/II S Pack
    Apr 2011
    As above, with a chunky car like that it needs bigger wheels to suit. Change them, clean up your drums and calipers, spray drums with black caliper paint and spray calipers with red or yellow caliper paint. Will look way better. With such a chunky rear end, it needs the bigger spoiler.
    WL Caprice
    Mar 2011
    Keep the wing. Otherwise get a new boot lid (probably cheaper than filling and respraying the current one).
    Look at the wheel colour and the calipers would be my suggestion.
    VKCOMMO's Avatar
    VKCOMMO is offline Carpark Mechanic.....
    Aug 2009
    Springwood, NSW
    Remember, the holes will be in your boot afterwards..
    [09-01, 22:47] HoZy: VKC doesnt finger, He fists... Because Ranga
    VS Berlina
    Mar 2011
    Woodford QLD
    The wing looks good I would leave it there. They are right, there is a problem with the wheels. They need to fill the guards more, the kit makes the wheel arches look wider and the wheels are disappearing under the car.
    I dont mind the wheels themselves.. maybe just a different offset and/or slightly wider, to fill the wheel arches properly.
  15. #15
    dobesz's Avatar
    dobesz is offline 355ssute
    vs ss ute
    Oct 2009
  16. #16
    Verynice's Avatar
    Verynice is offline Band
    VS Caprice 5L
    Aug 2008
    SA - The Backwards State
    needs the wing. it completes it, otherwise just looks like a half-assed attempt of chucking on a kit.
  17. #17
    VS Berlina
    Mar 2011
    Woodford QLD
    Quote Originally Posted by dobesz View Post
    It will be stuck on with sicaflex
    Its more likely that the rubber insulators between the wing and the bootlid have softened and are acting like glue. If you pull hard enough on it, it will come off, but that will probably still leave some of the insulator behind as a gluey mess on the boot, and of course 4 holes in the boot.
    If you wanted to remove it, and you cant do the body and spray work yourself, then better to get a new boot and have it sprayed than messing about with that one. Just ebay the old boot complete with spoiler, untouched... someone will buy it.
    I still say keep the wing, it suits the kit.
  1. [NSW] FS irs springs senator wing s pack wing other stuff
    By FA-77-VY in forum Parts And Other Items For Sale
    Last Post: 26-09-2009, 09:09 PM
  2. [NSW] VY/VZ Grange Wing & VY Spac Wing
    By FAT.36L in forum Parts And Other Items For Sale
    Last Post: 17-08-2009, 07:37 PM
  3. SWAP: Vxss boot with wing for no wing
    By RUN41T in forum Swap / Wanted to Buy / Trade
    Last Post: 19-07-2008, 10:20 PM
