Results 1 to 3 of 3
Thread: Struts
    2003 VY SS series 2
    Sep 2009
    Brisvegas
    Default Struts
    Hi all,
    Just a question about stretch bolts for the vy struts. I have seen on another forum saying you need to replace the stretch bolts, is this right? Why cant you use the same ones?
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    They are called stretch bolts because as they torque up they stretch to reach the torque setting.
    This stretch acts a little like a spring keeping the bolt in tension while it is under torque.
    Problem is that each time you torque up the bolt it will stratch a little more so there is the prospect of the bolt maybe snapping.
    Saying all that, when you get a full front wheel alignment (a proper one not a toe and go) they will sometime have to back off those bolts to adjust the camber so out the window goes the argument for not reusing them.
    I have reused mine, sometimes more than a few times.
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
    2003 VY SS series 2
    Sep 2009
    Brisvegas
    I understood the whole "stretch" side of things, but i was under the impression that if it was torqued to the right setting, there wouldnt be any issues, cause its not be tightened past its limit. I think i will just reuse them, and just use loctite aswell. Cheers for the reply
  1. VY SS Struts
    By AUSFITTER in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-10-2011, 03:08 PM
  2. are these the same ? (hsv struts to SSV struts)
    By geo41e in forum VE Holden Commodore (2006 - ?)
    Last Post: 23-08-2010, 07:22 PM
  3. What struts do you use??
    By undar8ed1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-01-2009, 07:36 PM
  4. Do VT struts fit a VS?
    By martinarmstrong in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-02-2006, 06:17 PM
  5. anyone used air struts before?
    By vrmica in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-01-2006, 08:55 AM
