Results 1 to 3 of 3
Thread: Compression test v6
    VY V6 Wagon
    May 2009
    Tauranga NZ
    Default Compression test v6
    Want to do a comp test to find out if oil sign on no5 plug is rings or stem seals but cant get it to fit. Its a Stanley Compression tester and it seems the thread is too short to engage in the head - any hot tips? Cheers
    VY SII HBD Calais L67
    Dec 2006
    Get the right compression tester adaptor. Doing a comp test is serious stuff as it's to rule out or diagnose terminal issues with an engine. It must be done right to avoid re working a fault
    VYII Calais L67
    VX2 Equipe
    Aug 2010
    I have done both my Ecotec's in VX II's and got very high readings of 200 to 205 PSI.
    One had 230,000 on it and the current one has 125,000 on it.
    These things would appear to have very good ring sealing.
    Hope this helps.
    Regards
  1. Vs v6 compression test
    By juzzyx in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-02-2011, 09:14 PM
  2. how to do a compression test?
    By admir87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-09-2010, 09:46 PM
  3. Compression Test
    By Deutscher in forum General
    Last Post: 09-04-2010, 03:46 PM
  4. Compression Test
    By commy vk in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-01-2010, 10:34 AM
  5. 5.0 Compression Test Results
    By Noy in forum V8 Development and Modification
    Last Post: 11-03-2009, 04:52 PM
