Results 1 to 11 of 11
Thread: Gen 111 Adventra
    MORT Guest
    Default Gen 111 Adventra
    Hi people
    Am a first time owner of a australian car being a vy adventra CX8
    and have a question most of you will laugh at.
    What is the difference between ls1 and ls2?
    Also what problems have the alloy v8s now the oil problem is sorted,and what mods were made to stop the oil useage?
    Also have the front bar recall and new half shafts fitted in the rear to stop cv like noises and all other minor probs worked out however I have rather an annoying vibration/harshness only at 1100 rpm.Other gen111 motors I have driven dont seem to have this problem.
    Any feed back appreciated
    Mort
    WK Statesman 5.7L
    Aug 2005
    Sydney, NSW
    The LS1 is the 5.7L and the LS2 is the HSV 6L. Some people say that it is a completly different engines and others say that its just bored out to 6L. Cant help you with your other questions.
    VL, VH V8 wag, Zook Vitara.
    Apr 2005
    Ardlethan, NSW
    how bad is the vibration? cos i never noticed it in our cx8, but i will look out for it next time i'm driving it...maybe it's just 2 ton V8 thing.
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Quote Originally Posted by MORT
    Hi people
    Mort
    AFAIK the oil problem was fixed with revised piston rings. Neither of my 2 GenIII's have had that problem (yet).
    As somebody else said, LS1 = 5.7L, LS2 = 6.0L. I suspect it is just a newwer version of the GenIII. Kinda like the 3.8L V6 changed to the ecotech in the mid 90's.
    Vibrations could be caused by anything. if it only happens at certain speeds (rather than rpm in different gears) I'd be looking at tail shaft uni joints, centre bearings, wheel balancing. If you have had the 1/2 shafts replaced, maybe one isn't balanced too well. Take it back to GMH - they should be able to fix it for you.
    Reaper
    VY1 HSV Clubsport R8 M6
    Oct 2005
    Western Subs Melbourne
    Quote Originally Posted by scott.waldon
    NO, it is a totally new block, but, they do say the LS1 heads will fit it and vice versa. Not that you'd want to do it!! Strange thing is though, on paper it is only a 2.6mm difference in bore width and it still has a 92mm stroke!
    MORT Guest
    Default Gen 111 Adv
    Thanks for the help people.
    The vibration in question is not a road speed problem becaust it does it at standstill. It seems to me like an out of ballance feeling just at 1000 to 1200 rpm. I thought initially it may have been a leaking valve. If it were a multi carb model i sugest it could be a carb not pulling its weight ie poorly synchronised??
    The guys at the dealership say a lot of gen 111s behave poorly like this down low. I hear the difference in firing order may be the cause of imballance also?
    Do they have a different firing order and compared to what engines?
    Thanks
    Mort
    Reaper's Avatar
    Aug 2004
    Thanks
    Mort
    My GenIII's runs fine. It isn't the most torquy engine down low but it does run fine. I tow with it 90% of the time and it pulls 2 ton of trailer ok.
    I doubt you would have a carby problem - fuel injection kinda took care of that. It will be a balancing issue somewhere - get them to check the harmonic balancer at the front of the engine for a start.
    Reaper
    VY CX8 Adventura
    Dec 2008
    Default Problem with vibration
    Hi all,
    I was reading about a problem with the Adventra. I am curious about the vibration you have?????? I have a 2004 VY CX8 V8 which has had a vibration at approx 95-100km per hour (around 97km to be precise) I was first told it was the tyres (3 1/2 years ago) which had a feathered effect so you can imagine my surprise when we had the tyres replaced and the vibration is still there. I have had it back to Holden for this problem (this is now the 4th time) 4 years on - and they still cannot find the problem. They have replaced the torque converter 3 times, recondiotioned the auto trans, sent the tail shaft for repairs - centre bearing had play, found gears burnt out in the gearbox, suggested the drive shaft was warped but never changed, the diff was making a noise and found trunions noisy. They fixed this by applying a special glue which eliminated a whirring noise we also had in the car. In the time we have had the car I have taken it back to Holden no less that 15 times (twice the required amount) for issues with this car. Whilst it has all been fixed under warranty the inconvenience and facing the possibility we have a faulty car that we spent $45k on is depressing. Have you heard about any other Adventra's with vibration as we are obviously not the only ones. Holden still has our car and is still investigating but told us they need their courtesy car back and dont know what more they can do??? Does anyone have any suggestions as to what else the problem could be???
    wetwork65's Avatar
    wetwork65 is offline A wet business
    VY Berlina V8 & VZ Adventra LX8
    Mar 2006
    With the goblins in South West WA
    Doesn't really help but mine (LX8) does the same - vibration @ 97/99 km/h.
    Tyres? Wheels? dunno - would love to find it.
    Mercedes C200K AMG-Sports
    Mar 2007
    Quote Originally Posted by shazm View Post
    Hi all,
    That sucks. I got a VX commodore (for sale now) which is in perfect condition but I get a vibration at speeds of about 100km/h. I just bought a used WK Caprice and it also has a slight vibration. If you can be so kind to let me know what it is when its fixed that would be great. If I get mine fix, I will do the same.
    I too took my caprice to holden (didnt care to much about the VX) and they couldnt find the issue. They said replace the tyres but I am sceptical of this.
    Bottom line is next time I want the issue looked at I will take it to an independent mechanic not holden.
    funny thing... on my VX I once had the front tyres changed and it didnt fix the issue. Then a few months later I got the front tyres changed again and the issue went away. The I bought alloy wheels and changed the rims and is back again.
    minux's Avatar
    minux is offline Infidel Bear
    300rwkw FG G6ET/2011 Sti Spec R Hatch
    Mini Putt 2 Champion!
    Feb 2005
    guys this thread is over 3 years old...
    "Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind."
    - Theodor Seuss Geisel
  1. VZ Adventra SX6/CX6
    By Torquative in forum General
    Last Post: 04-02-2011, 05:23 PM
  2. Adventra ideas
    By spud308 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 08-08-2006, 12:20 AM
  3. Adventra
    By Stretchomatic in forum VY Holden Commodore (2002 - 2004)
    Last Post: 18-06-2005, 10:12 PM
  4. VZ Adventra
    By chris87 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-09-2004, 10:49 PM
  5. Holden Adventra
    By Commodore in forum General
    Last Post: 30-08-2004, 07:33 PM
