hi as the title says im needing help on how to change the volume controls on the steering wheel. Is there a step by step guide on how to do this
disconection of the bat leave for 5 min so the air bag dose not go off the get a thin blade screw driver and locate the 4 holes on the back of the steering wheel insert the blade into one of the holes and twist pulling on the same side that your working on then repeat for the rest of them then slowly pull the air bag off then remove the red wire off the air bag then i think you should be able to do the rest after that
VY HSV SENATOR 2003
301.3RWKW ON 20INCH RIMS
if i disconnect the battery will it loose the memory for my mafless tune?
no mate it's stored in your ecu it's not going to shit it's self i did it to mine last week and it has a mafless tune and it still going strong
VY HSV SENATOR 2003
Cheers mate
Screw driver can work I found using a Allen key the L shaped ones works easier. Put the smaller length in said whole and pull away from the centre. Also disconnect the fuse under the dash just as a extra measure.
CAM'S VY PHREDDIFIED AND LEATHERED!
http://forums.justcommodores.com.au/...w-leather.html
