Results 1 to 7 of 7
Thread: pulleys
    V.Y SS Commodore 5.7 6 speed manual Cammed
    Aug 2011
    Whyalla S.A
    Default pulleys
    As the title says im after a diagram of the pulleys on the front of the engine and labelled which ones are which as i got a noise one and wanting to find out wat it is called so i can replace it...
    cheers
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Easiest way would be to walk into your local parts supplier and they should have a diagram on their computer.
    From VS thread but they should be the same-
    Attached Thumbnails Attached Thumbnails pulleys-imageuploadedbytapatalk1321251118.809387.jpg
    Aug 2011
    Whyalla S.A
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    The ones labelled starting "EP" are the idler pulleys and part numbers for replacement "Nu-line" Brand.
    Power is measured in DECIBEL
    Aug 2011
    Whyalla S.A
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    I knows Scotts have em in stock usually, not sure about Repco
    Aug 2011
    Whyalla S.A
    so the bottom ep025 near the ac compressor is that a idler pulley or just a tensioner pulley
  1. Under dirve pulleys
    By doms1 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-07-2010, 11:54 AM
  2. VY sv8 pulleys.
    By Robbo5390 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 20-03-2010, 12:54 PM
  3. pulleys or something else?
    By plasmid2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-11-2009, 04:07 PM
  4. VS V6 Pulleys
    By r_i_d_a_h in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-02-2008, 07:53 PM
