Hey there Got this fuel smell coming in to the car Only when i'm on the highway so sitting on 100k Happened 3 times now Cant get it to do it around town Any good places to check? Injectors look a bit dirty around the o-rings but if they were at fault wouldn't i smell it all the time.
is there a build up of dirt or moisture around them. get some degreaser and clean around them and see if it builds up quick
also check your fuel lines for leaks
Good idea will give it a try they might be leaking slowly but more under high load. Cars done 185.000
