Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By TMM
Thread: A/c Fan VY 2002
    VY Berlina
    Nov 2011
    Hampton Park Victoria
    Default A/c Fan VY 2002
    The a/c work only works on Level 5 Full Blower , it does not work on the control fan setting ie level 1,2,3 or 4 ? the Bride is nagging me to fix it ! Can any let me know if they have had this problem & how to fix it ?
    Thanks
    Oct 2004
    Its a Blown Fan Resistor, not an expensive fix im sure theres a guide on here somewhere
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    For a VY Berlina? The climate control units don't use a resistor, instead there is a TO-3 transistor attached to a large heatsink. What happens is there is a solder joint on the transistor unit that becomes dry and one of the metal links/wire connecting the transistor to the plug pops off. You just have to resolder that link and it works again.
    From memory (not sure if this is 100% correct but you get the idea):
    Remove the glovebox; push two rubber tabs in either side, glovebox should now open further, then just unclip the entire glovebox at the hinges.
    Remove the trim under the dash that has the footwell light in it
    Remove the footwell A/C duct
    you should be able to see the transistor/heatsink up toward the center console now. Iirc there is a metal support that is in the way. I just undid the screw on one end and that gave me enough clearance to get the transistor out.
    VY Berlina
    Nov 2011
    Thanks Mate for the advice , done everything as you said above , i removed the unit & pull it apart & inspect everything look well soldered , Guess i need a replacement unit . thanks for your help again , Cheers
  1. [SA] 2002 vu ute
    By skyline_r33_panda in forum Vehicles For Sale
    Last Post: 20-02-2011, 09:37 PM
  2. 2002 VX s2 , my first car
    By james VX in forum VT - VX - VU - WH - V2
    Last Post: 12-03-2007, 08:13 PM
  3. My 2002 vy
    By MyVy in forum VY - VZ - WK - WL - V2
    Last Post: 19-11-2006, 07:50 PM
  4. 2002 Vx
    By VH Vacationer in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-09-2006, 06:10 PM
  5. 2002 VX S2 Acclaim OR 2002 VX S2 SSpack
    By ruso in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-05-2006, 10:53 PM
