I want to check the selector switch on my air con and the vacuum hoses from it. How do get to the back of the switch and is the location for the vacuum hoses behind the glove box of behind the switch. Need to the nest way to get to the areas.
Thanks in advance.
P.S. my problem is the recycle setting ends up going to the windscreen setting after a short time. So checking for leaks.
