Results 1 to 13 of 13
Thread: Problem after injector change
    VY 03
    Aug 2005
    Default Problem after injector change
    Hey there I installed some new injectors today all went well untill i went to start the car I waited for the fuel pump but I heard spraying coming from the engine Now 1 of the injectors on the passenger side wont seal Ive tried new o rings and old ones still wont seal Ive reseated them about 4 times now with no luck.
    VY S Series 2
    May 2010
    VY 03
    Aug 2005
    It was from the top of the injector I ended up using one of my old o rings which still looked good and its now sealing 3 o rings later Taken it for a decent drive all is fine now
    VY 03
    Aug 2005
    fixed again slight bend in fule rail making the injector sit on an angle not sealing
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Did u lube the o rings when fitting the injectors or smash them in dry?
    Silver Certified.
    wraith's Avatar
    wraith is online now Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    Are you sure you removed the old o ring from the injector rail. You should never reuse the o rings when you do the injectors.
    VY 03
    Aug 2005
    They are all new o-rings One of the out lets on the fuel rail was slightly bent so that one injector was not sitting inline I placed a old injector in that spot and slightly bent it back in Wasnt hard to bend Seems fine now been driving and no sign of leaking fuel It also looks more alligned now. 3rd car ive done them on only this one gave me problems
    VY 03
    Aug 2005
    Still going good not leaking But when i was doing the job i noticed a split in the vacuum hose from the fuel pressure regulator to the plenum So i went and bought another when i got home i noticed its only about 5 mm and the stock one was about 6-7 Would this matter cause its now rough on start like its going to stall for a split second then bang it starts.
    VY 03
    Aug 2005
    Replaced hose back to the normal size still rough start. Fuel around town is now 15L/100k as 13.5 before :S
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Could have a leaky injector. If you run it for a while then turn off and straight back on again does it start nice?
    Silver Certified.
    VY 03
    Aug 2005
    Yep It will start better after its been running for say 10 mins or so. Thought one might have been a bit leaky But they are all very clean around the o-rings as i degreased the inlet manifold while i did the gasket so its easy to tell.
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Leaking as in the injector isnt closing properly and is dribbling fuel into the cylinder
    Silver Certified.
    VY 03
    Aug 2005
    It starts first go not a cranking problem just rough idle on start for a few seconds I went to start it yesterday and heard a air discharge Opened the bonnet to find the vacume hose had poped it self off and i could slide the hose out of its sleeve I matched the ends up pluged it back in 2 good starts now out of 3 Time to try a new one
  1. Injector flow rate change
    By freax in forum V6 Development And Modification
    Last Post: 28-09-2011, 09:30 AM
  2. How hard is it to change an injector?
    By gambit120 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-01-2011, 04:56 PM
  3. !Help. VS will not start after injector change
    By nathanVY in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-10-2010, 06:20 AM
  4. Injector problem
    By hank in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-04-2006, 10:02 PM
