if i ran two flexi pipes, one from each side of the air box, to infront of the radiator, when it rains, would water go into the engine? :/ or even the normal way of doing the two hole mod?
Is there even any room to get the pipes to the front of the radiator?
Silver Certified.
i run a pipe from the engine side of the box straight down then 90deg turn to face the front under the bar... no leaves or water for a good 8 months now..
thanks for the feed back guys![]()
If you have a V6, doing anything other than FI to the engine to get more power is a waste of time and money. If you really want to go quicker on a budget, get some diff gears.
Forced induction isn't everyones cup of tea you know? Some people arent on the quest for the fastest v6 on the planet and actually appreciate N/A engines. But yes diff gears will make things a little better.
