Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By Munz
Thread: cooling fluid
    vts 1999 V6
    Oct 2011
    Default cooling fluid
    hi
    vy V8 had a new radiator installed plus thermostat and housing but the coolant is green coloured not the pinkish it had from the factory
    should I get it changed?????
    thanks
    03 VY SS 5.7L M6
    Feb 2009
    Enoggera QLD
    304runner's Avatar
    304runner is offline ( .Y. )
    VR 5.0 Ute & a 4runner with a VS SS trasplant
    Mar 2011
    Central Coast NSW
    I didn't think that the green coolant was corrosive to alloy?
    But I don't own an LS1 so, yeah....
    Vk ls1 turbo
    Aug 2009
    townsville
    Yea change it to the red stuff .
    2002 HSV GTO COUPE
    VK calais ls1 turbo conversion (in the build)
    2009 turbo v8 landcruiser
    My VK http://forums.justcommodores.com.au/...-vk-355-a.html
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    Take it back and tell them to change it unless they will be up for a new engine
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    ^ what he said
    Quote Originally Posted by Rufys View Post
    yup! I think I might actually be gay
    vts 1999 V6
    Oct 2011
    vts 1999 V6
    Oct 2011
    I've been tolled that the colour is only a dye and you can buy coolant for alloy motors in green?
    Dec 2009
    The red and green signify 2 different types of coolant. Have a look at the Nulon web site they give the details there. I understood the green stuff was OK to use in a V8 as long as the red stuff was totally flushed out as they do not mix. you could find out the brand they used and give the manufacturer a call but no they are not the same except for the colour dye.
    03 VY SS 5.7L M6
    Feb 2009
    Enoggera QLD
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    The green coolant is perfectly fine, just make sure you get it changed every 2 years because it doesn't have as long a life span as the red stuff (5 years). That said, the factory red coolant is usually well toast at 5 years anyway...
    V.Y SS Commodore 5.7 6 speed manual Cammed
    Aug 2011
    Whyalla S.A
    i been told there is a specific orange colour coolant for the gen 3 as there alloy blocks GM specifically made this coolant for them... in saying that i got green in mine so im gonna do a radiator flush and change to the orange coolant
    Dec 2009
    VY SS Ute
    Jan 2011
    The colour is just a DYE. Has sweet F all to do with the active ingredients. Manufacturers may use it to differentiate between coolants from there own range, but then if you change brands, the colour may well be different.
  1. trans fluid and power steering fluid
    By jabba13 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-02-2011, 09:51 PM
  2. Brake Fluid and Auto Trans Fluid.
    By Melchior3 in forum General
    Last Post: 20-02-2006, 11:49 AM
  3. VS air con not cooling.
    By shmity in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-12-2005, 07:46 AM
  4. Amp Cooling
    By VY2ENJOY in forum Car Audio
    Last Post: 22-10-2005, 12:54 AM
  5. vn s1 cooling
    By fatvgute in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-07-2005, 11:24 PM
