Results 1 to 11 of 11
Thread: stock or aftermarket cruise control
    vx II executie
    Aug 2010
    hervey bay
    Default stock or aftermarket cruise control
    hi, am going to get a cruise control fitted to exec.
    have been told $699 fitted from pmr. for an ap500 and cm30 stalk.
    and from an auto elec
    he can get from holden 498 think he said the factory kit, and said that he hasn't fitted one into a vy before so was guessing about 4 hours to do the job making it $820. but could be less if he does it quicker.. he'll prob turn around and say it took him the full 4 hours even it if it didn't..
    would the holden cruise be alot better then the aftermarket commander one. and does anyone know how long it should actually take to install the one from holden?
    thanks
    vx II executie
    Aug 2010
    hervey bay
    seems as thought no one has an opinion on stock or aftermarket cruise controls.
    how about has anyone fitted a stock cruise control onto an exec? how long it took? contemplating even doing it myself
    VY S Series 2
    May 2010
    i wouldnt think it would be too hard to fit... never done it myself but the only thing would be the wiring and as long as you can get a diagram it shouldnt be too hard
    03 VY SS 5.7L M6
    Feb 2009
    Enoggera QLD
    If the loom is already there its plug and play i did my old vx lumina in a few hrs following the instructions that came with the holden kit
    vx II executie
    Aug 2010
    hervey bay
    Quote Originally Posted by VY Rossi View Post
    how can i find out if it is?
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    Xw GT replica/Vr s ute/Ef
    Jul 2011
    NSW
    I would just go for holden why not second hand ? From a wreck you will save big $$$ and if your not keen on fitting it just get a mechanic or eletriction to do it.
    Originally Posted by 87RB30VL
    Huh? I got given the gun of my neighbour,
    vx II executie
    Aug 2010
    hervey bay
    went into holden today.. and yes they can get a kit from brissie at $497, he spoke to one of the guys in the workshop who told him it's a big job, about 6hours.. problem apparently is getting to and cutting a hole in the firewall for the cabling, which takes ages, cutting the whole in the right place?
    so getting them to do it would be over a grand.. way to much.
    nothing at a wreckers localy. so rang several in brissie, only found 1 who said he had, and would be $220, but won't post.
    GothicKidd's Avatar
    GothicKidd is online now ლ(ಠ益ಠლ
    Series II VR Commodore
    Dec 2010
    South Australia
    What the? There would be hardly any cutting involved? Its only 6-10 wires to the Cruise control module? I do believe they all came stock with the wiring? but only optioned if you wanted it or not.. Have a look in your engine bay to see if you have the connection there.. Should be on the drivers side.. If you have that.. Its almost plug and play..Although you'll need the Module and Stalk. and should be right.
    $699???? Sounds like holdens. Probably $100 parts.. and $599 labor.
    GothicKidd's Ride
    I push the pedal to the floor, smoke them up and go.
    vx II executie
    Aug 2010
    hervey bay
    yea i've had a look around in the engine bay, can't find any loose plugs or cabling of any kind not connected to anything
    would like to be able to get the factory kit installed. but if it's $600 labour thats just ridiculus
    GothicKidd's Avatar
    Dec 2010
    South Australia
    Labour at Holdens is ridiculous IMO.
    They suggested replacing my dads VU utes Power steering rack for $530 labour.. $230 for parts.
    I had mine replaced by my girlfriends uncles for $150.. and it was the best Powersteering rack the wrecker could get his hands on..
    and had holdens clean my throttle body.. $240.
    Save your self some cash, do it yourself or get even a wreckers to do it (some should do it)
    could be simple plug and play.. or a loom replacement..
    GothicKidd's Ride
  1. [General] [My VX] How to make your stock lights look aftermarket
    By Demoniak in forum Holden Commodore How-To's
    Last Post: 04-04-2012, 08:34 PM
  2. [General] [My VX] How to make your stock lights look aftermarket
    Last Post: 08-09-2011, 06:13 PM
  3. Much Difference in Stock or Aftermarket V6 Engine Mounts
    By redvpsenator in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-05-2011, 07:58 PM
  4. Aftermarket cruise control issues.
    By Stretchomatic in forum General
    Last Post: 02-08-2010, 09:11 PM
  5. Man conversion-cruise control, will the auto cruise control work on manual conversion
    By pjdm1980 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-08-2009, 12:25 PM
