Results 1 to 5 of 5
Thread: !!URGENT!! VY SV8 Transmission Problem !!URGENT!!
    VY SV8 5.7L
    May 2011
    Kadina,Yorke peninsula
    Default !!URGENT!! VY SV8 Transmission Problem !!URGENT!!
    Hey guys i have a VY SV8 commodore and now for some reason my transmission revs out high ONLY!! in first gear it wont change from 1st to second gear at about 4000Revs or higher, every other gear is fine. If you rev it high then slowly bring the revs down while driving it will drop into second,?
    DOES ANYONE KNOW WHAT THIS COULD BE?? REASON WHY ITS URGENT CAUSE IM ON A HOLIDAY ATM AND WONDERING IF ILL MAKE IT HOME!!! THANK YOU!!
    VY S Series 2
    May 2010
    so you have to go over 4000 revs and then dropback to get it to change or it just wont change over 4000rpm?? either way i wouldnt see any reason you wouldnt make it home with that problem as it doesnt appear to be tearing itself apart
    1998 Mercedes Vito 113
    Oct 2009
    S.E VIC
    I'd say you would make it home, I'm going to assume it's auto..
    You could try using the shift 1-2 gears on the way back if it helps.
    It's unlikely all the gears will just "drop out" and the box kill itself.. You should be able to get home easily.
    Anyone feel free to correct me.
    Quote Originally Posted by perkoracin
    it like u pull at to a red light and they go o its that fag from just Commodores and it like u go tohe drags and ur car runs a like a 9 sec run as a eg and theres run a low 14 um i would Lol so hard like Epicly and then call them The Internet Mouthers and no go Lol thats a eg they might have Fast as rides 2 but may not sound as a Nice small block chevy with a Supercharger on it lol.
    Click here for my old VY Commodore!
    VY SV8 5.7L
    May 2011
    Thanks for the reply it dont work changing gears manually and yes its auto lol
    And what do you think the problem could be?
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Check the fluid level for starters. Low fluid level will result in flaring between gears but unfortunately so will a box thats cactus.
    Silver Certified.
  1. [SA] VS 6HDD Transmission *Urgent*
    By someguy360 in forum Swap / Wanted to Buy / Trade
    Last Post: 25-11-2011, 09:41 AM
  2. *URGENT* VS V8 coughin fartin splutterin, occasionally stallin *URGENT*
    By holden_1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-08-2010, 05:08 PM
  3. Urgent VS Transmission Help Needed
    By Terror-D in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-02-2010, 11:25 AM
  4. Urgent Help Transmission
    By daggett in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-02-2005, 08:40 AM
