Results 1 to 6 of 6
Thread: VY non traction only has first two gears?
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Default VY non traction only has first two gears?
    Guy I work with has a VY exec series 2 and I'm assuming he has blown the trans, it only has first and second but the strange part is the dash has lit up like a Christmas tree
    - trac off
    - abs (light on)
    - srs (light on)
    - contact dealer
    - temp gauge has stopped working
    Just would like to know if a blown box would cause these lights and messages or could it be a dodgy computer?
    Side note he's 50 plus, original owner and this car gets driven like grandma car yet the box has let go at 250,000.
    Thanks for any help guys.
    VH SL/E...'09 dual cab 4X4 hilux
    Mar 2011
    roxby downs
    sounds like it could be going into "limp home mode".... best just to take it to the dealer and find out what the computer has to say.
    did the trans loose 3rd and 4th first and then the lights came on or was it all at the same time?
    If in doubt......FLOOR IT!!!
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Lights first then the gear box.
    And it just revs in third and fourth like I'd expect a blown box to do, I haven't had much experience with VY's.
    1998 Mercedes Vito 113
    Oct 2009
    S.E VIC
    I'd say the same as above, "limp home" mode.
    It's so something is wrong and it's the least-damaging/safest way to get home..
    Going to have to take it to a dealer.
    Quote Originally Posted by perkoracin
    it like u pull at to a red light and they go o its that fag from just Commodores and it like u go tohe drags and ur car runs a like a 9 sec run as a eg and theres run a low 14 um i would Lol so hard like Epicly and then call them The Internet Mouthers and no go Lol thats a eg they might have Fast as rides 2 but may not sound as a Nice small block chevy with a Supercharger on it lol.
    Click here for my old VY Commodore!
    VY SII HBD Calais L67
    Dec 2006
    Sounds like the ABS module has fried. Trans will only have 3rd as a default which as others said is limp home mode. Don't go to a holden dealer as your mate will need another mortgage to pay for it. Most work shops have ABS modules lying around to use for diagnosis.
    VYII Calais L67
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Well took it to a mate who is a wrecker/mechanic he replaced the front of the ABS module (bolt on plastic part) saved us bleeding the brakes got rid of all the codes but the trans still slipped so dropped the trans out and put in a second hand one and all is good like a new car must have just been a coincidence that the trans and module went at the same time.
    Thanks for all your help everyone.
  1. Vx ss ls1-abs & traction control lights stay on & traction control switch not work-
    By VTLS1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-01-2011, 05:57 AM
  2. low traction :S
    By kngsv6 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 04-10-2010, 09:30 PM
  3. !change of top speed in gears when fitting 3.7 diff gears.!!??
    By slappedvr in forum V6 Development And Modification
    Last Post: 30-01-2010, 09:54 PM
  4. Tacho (No Traction) into car with Traction?/
    By feistl in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-10-2009, 08:51 PM
  5. Car wont change gears, holds gears, and rough changes
    By pedrotski in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-09-2008, 06:35 PM
