Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By Sean880
Thread: Brake Squeal, VY SS UTE HELP!
    2003 VY SS Ute M6 2005 WRX STI
    Nov 2010
    Default Brake Squeal, VY SS UTE HELP!
    Hey guys Ive just bought myself a VY SS Ute and its managed to generate this annoying brake squeal, the rear slotted rotors and pads are fine and ive replaced the front pads with Bendix General CT and ive even used the special goo thats meant to prevent vibration/noise, and roughed up the front rotors with sand paper, but ive still got the same noise from when the old pads were in it, nothing has changed! the only thing I can think of is to replace the front rotors but they dont have a lip or anything! what could it be? its so annoying! Any help muchly appreciated, cheers!
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    I don't understand how a diamond shaped brake pad doesn't make noise --> General CT | Bendix
    I thought it had to be a flat surface, but if the noise is the same after both pad changes - maybe it could be rotors
    Also shimms on the pads could help if the bendix don't come with them from the factory
    Edit: also get out and stand on the brakes hard sometimes they need to be really worn in!!!
    Nov 2010
    Yeah I have reused the old shims on the new Bendix pads but still have the same noise, the only thing I can think of to do is replace the front rotors? but they dont even have a lip, and I suppose I could stand on em a few times to see if that helps?
    VY II S V6 Supercharged and 911 Porsche 996 3.6
    May 2009
    VIC / NSW
    Quote Originally Posted by vsute97 View Post
    I suspect there could be a poor level of contact between the brake pads and the rotors. The first thing I would be doing is having the rotors machined provided you will still have minimum thickness remaining. (BTW never "rough them up" as you did with any scouring material). If you cannot have the rotors machined without going below minimum thickness then replace them.
    BTW I would never just replace brake pads without either machining the discs or replacing them at the same time. They are inexpensive to replace when you consider the life you get from new items of sound quality.
  1. brake squeal
    By 316 in forum VE Holden Commodore (2006 - ?)
    Last Post: 13-05-2011, 03:44 PM
  2. Brake squeal
    By .Holdon. in forum General
    Last Post: 18-10-2009, 07:32 PM
  3. Brake squeal
    By chromic in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-01-2008, 05:45 PM
  4. Brake Shudder / Squeal
    By Butso in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-12-2005, 07:34 PM
  5. Brake squeal
    By corindi in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-10-2005, 02:17 AM
