Results 1 to 8 of 8
Thread: Stereo Stuck
    VY II SS M6
    Dec 2011
    Melbourne, Australia
    Default Stereo Stuck
    I've got a VY II SS Commodore and I just can't get the stereo out of the dash. I've gone through multiple stereo removal tools that I've bought on eBay and I just can't get the stereo to slide out. I've probably spent 3 hours all up trying to get it out and end up with the tools bending and no luck.
    The previous owner did say that the stereo was replaced with an identical factory Blaupunkt 6 stacker unit due to an issue, and I'm guessing when the new one was slid in, it has gotten stuck somehow.
    Does anyone know how I can get it out? I'm looking to get the AUX connectivity done and am fed up with the bad sound quality of FM transmitters. Any help would be appreciated!
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    Your not alone mate, I too had the same issue with my stock head unit, i had to break the front face plate off to get the bugger out, but i did not car since i installed a new head unit since this one was skipping all over. i do miss the factory finish though.
    Make sure you are pushing the tools all the way in, and pushing them both out wards to push the clips into the head unit, then pull while pushing out.
    VY Executive S2
    Jan 2010
    just take it to your local car stereo place im sure they'll charge nothing to 10 bucks
    VY 5.7 Cross8
    Nov 2011
    Hi mate,
    Mine was a bit stuck so I took the sides of the console and levered it out from inside.
    I didnt have the removal tools either I just used kebab sticks to hold the spring clips in while I levered it out.
    Looking back it is probably easiest to get to from the bottom front, once you take the cover over the center console.
    If you can't do it yourself, or find a stereo place to do it for you drop out to Doncaster and I'll have a crack at it for you.
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    Are you pushing the tools in until they click? This is critical because the notches on the ends of the tools engage a raised part of the spring clips, which is what pulls the headunit out. If you are doing it properly, the tool should be virtually stuck in the headunit until you pull the whole unit out!
    Push them in hard until they click, then lever both tools outwards slightly (left tool to the left, right tool to the right) and pull toward you at the same time, it can require some force. I find it easier to do while sitting in the passenger seat.
    kcpwns's Avatar
    kcpwns is offline Kicker - Livin' Loud :)
    VY V6 Equipe
    Jan 2010
    Shepparton
    i had to use me and a mate holding each tool...aftter hours of struggling he grabbed one side and i grabbed the other and it just fell out
    Quote Originally Posted by some_guy View Post
    This posts stupidity makes baby jesus cry.
    My Ride
    currently retrofitting projector headlights
    Vz Calais 05 alloytec190
    Dec 2011
    Skye, vic
    Just get some metal coat hangers, cut them about 30cm long... Bend it so they are straight, that should work It worked a charm for mine. Even if they are slightly out of whack it would at least grab the edges to help pull out.
    [BUMP]. *mrs: WTF was that!?!?* *me: nothing, just don't look back -_-*
    VE SSV MY10
    Jun 2006
    Good thick coat hanger made up to fit works every time for me takes me about 10 sec to remove a factory head unit
  1. Stuck CD
    By f1_power in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-10-2010, 10:44 PM
  2. !!!!stuck!!!!
    By jaron88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-06-2010, 12:33 PM
  3. im stuck what to do next?
    By calais_304 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-04-2007, 10:45 AM
  4. CD Stuck
    By VZCalZone in forum Car Audio
    Last Post: 26-04-2006, 11:48 PM
  5. What Ya Got Stuck On Ya Car
    By soulyouth in forum The Pub
    Last Post: 04-08-2005, 09:21 AM
