Results 1 to 6 of 6
Thread: HELP! Low oil pressure LS1
    VY II SS Ute
    Dec 2008
    Default HELP! Low oil pressure LS1
    Hi all, i recently recieved a 'check oil' warning on my display, so i checked and changed oil and filter, origional oil was at correct level and no leaks have been found. However since changing the oil and filter the display still comes up 'check oil' on random start-ups (cold or hot). there is a knocking coming from the engine sometimes loud sometimes quiet. I am aware this means low oil pressure and is not a good thing, but if you get the engine working and hit it to about 3k-4k revs the oil pressure comes back and the light goes away. I have stopped driving for obvious reasons, but i desperatly need to know what is wrong. I was informed by a couple of mechanics this does not sound like a dead pump, because some days it was fine and no noise at all and if the pump was gone it would be a more consistent thing.
    Oil went from standard Holden oil (castrol edge I believe) to 15w 50 Nulon and a K&N Oil filter. No change btween new and old oil indicates to me this is not the problem.
    Any help appreciated
    VY SII HBD Calais L67
    Dec 2006
    Check oil pressure with an independent oil pressure gauge. Oil pressure switches are a common failure on the Gen V8s but needs to be diagnosed correctly sooner than later
    VYII Calais L67
    VY II S V6 Supercharged and 911 Porsche 996 3.6
    May 2009
    VIC / NSW
    1. As posted above, definitely have an independent pressure gauge hooked up to check the pressure readings.
    2. If low pressure is confirmed, but the pump is OK, I suspect the likely problem is a fault/malfunction with the oil pressure relief valve. ( If that proves to be OK I would probably be inspecting the oil pick up unit next to ensure it is clean and there is nothing impairing oil flow).
    VY II SS Ute
    Dec 2008
    Well I also thought pressure release valve, but thought it to be too random when the pressure is low, if the valve is malfunctioning wouldn't it be a more persistent problem. I read somewhere you can check if the oil sensor is functioning by looking at the connection and check for oil and dirt, but also read it can be difficult to replace and reconect
    VY II SS Ute
    Dec 2008
    Also what does the oil pressure switch do? If it lets the engine know what pressure to maintain this could be the problem but I don't understand why the prussure returns when the engine gets some revs and doesn't drop again. It's usually on a first start occasion but sometimes does it when the engine is at opperating temp, but only ever happens upon startup never while the engine is running
    VZ SS UTE
    Nov 2010
    Default Help I'm having the exact same prob
    Quote Originally Posted by DazzaVTS View Post
    Im having the same drama what end up being the problem?
  1. vx oil pressure
    By airforceone in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-01-2011, 01:45 AM
  2. low oil pressure when hot
    By V-ahhh in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-11-2006, 10:05 PM
  3. No oil pressure
    By SSbeast in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-11-2006, 10:23 PM
  4. oil pressure gauge, oil pressure
    By VN-88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-10-2005, 10:31 PM
