is it possible to remove the material part to be recovered without removing the full door trim? If so how?
Thank you for reading
No it's not sorry
There is screws behind to remove the material part
Nope. And the nuts holding that Plastic section are bastards to get off too.
hmm well fun times are to be hadthank you for the answers
It's a piece of piss. Remove door trim and you'll see the shitty little nut things that need to be removed.
this new question is some what related... how do i remove the trim inside above the door... pictures would be awesome but not inportant
Do you mean the piece that runs up the side of your windscreen? If so, remove the jesus handles and the cap and screw at the top of the B pillar, then it all unclips as you GENTLY prise it off. Careful, though, if it's brittle it can crack. Ive had mine of a few times to paint/vinyl wrap them and when installing my oil pressure gauge.
yep thats the one.. ok sounds simple.. just have to work out how to get the handles off now lol
