So I turned my car on this morning and went to turn the fan on but it wasn't working .
A/C works and so does everything else, just the 1,2,3,4 fan controll won't work, it's not the fuse either
Any help apreciated![]()
Last edited by Framd0; 10-12-2011 at 11:29 AM. Reason: Fan dosent work on high either
If it works on number 4 it's the variable speed resistor needs replacing
Dosent work on that one either
blower fan might be stuffed then do u have a test light and see if power is getting to the fan and check to see if the plug has not come off the back of the switch
Cheers mate I'll try that
Unplugged it, plugged it back in and it randomly started working agin![]()
