Results 1 to 4 of 4
Thread: v6 throttle body
    Vy commodore
    Mar 2008
    Default v6 throttle body
    Hi guys,
    Just installed my new mace 69mm tb to car.
    When I started the car for first time i notice that it now idle's around 2000
    Is this normal what can i do to fix this
    VY Clubsport R8
    Sep 2010
    Did you reset the ECU? Did you have the battery disconnected whilst removing your TPS and IAC? This may be the culprit to your situation. Try resetting ECU, search JC forums on how to reset an ECU.
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    Vy commodore
    Mar 2008
    Thanks guys problem solved after reseting ecu
  1. throttle body
    By nathan01 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-09-2011, 08:40 PM
  2. [SA] 304 manifold injectors injector rail and throttle body , 70mm throttle body suit v8
    By slywgn1 in forum Parts And Other Items For Sale
    Last Post: 10-06-2010, 08:42 PM
  3. vy ss throttle body
    By mattv8ute in forum VY Holden Commodore (2002 - 2004)
    Last Post: 26-04-2010, 05:20 PM
  4. Throttle body
    By sxc_sound in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-10-2008, 05:51 PM
  5. v8 throttle body
    By vnv88u in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-01-2006, 04:10 PM
