Results 1 to 10 of 10
Thread: need help installing a strut brace in a vy lumina series 1
    VY Lumina
    Jun 2011
    adelaide
    Default need help installing a strut brace in a vy lumina series 1
    just looking at my car i dont see any holes?
    some install pics would be awesome if you guys have any
    thank you
    ozzy
    VY Clubsport R8
    Sep 2010
    You will need to drill holes for it and I think you need to remove both struts and put the bolts from underneath and tighten from the top.
    VY Lumina
    Jun 2011
    adelaide
    ok.. would i need to remove the struts b4 i drill? or is there room under there to drill 1st then remove the struts?
    VY S Series 2
    May 2010
    your gonna need to pull the struts out first... there is no room at all otherwise
    vx
    Aug 2011
    sa
    Dec 2009
    Quote Originally Posted by loopie View Post
    dont they come with studs/ mounts from the factory on the towers
    Not accross the entire range until Series 2.
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Quote Originally Posted by wortus View Post
    Glad I have a series 2. But I thought the series 1 had those studs, too?
    s/charged v6 HR Holden, s/charged v6 EH Holden,
    Sep 2007
    You can also just drop the struts down about 20mm by undoing the top mount nut but not all the way , drill your holes & you can JUST get your fingers in between the top of the strut & the strut cavity to feed your bolts thru & get a spanner on to tighten them up. This saves having to undo the struts totally , then you need a wheel alignment too if you totally remove them.
    HSV 2003 GTO Coupe
    May 2011
    Auckland New Zealand
    I had a 2003 SV8 that had studs for a strut brace so the first install was easy.
    The current 2003 HSV GTO doesn't have any studs so I drilled the holes very carefully and used 8mm rivnuts.
    You can get raised or countersunk rivnuts. Only problem is the rivnut tool is a bit expensive. About $250 here in NZ.
    VY Lumina
    Jun 2011
    adelaide
    couldnt get the struts down very far and hands didnt fit so i used a wire coat hanger to get the bolts in
  1. strut brace bar?
    By rk has a vn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-10-2011, 05:41 PM
  2. Strut Brace
    By 89 vn in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-07-2008, 11:04 PM
  3. Vy strut brace
    By sickhg in forum VY Holden Commodore (2002 - 2004)
    Last Post: 31-10-2007, 03:55 PM
  4. WTB VR strut brace
    By madvrcom in forum Swap / Wanted to Buy / Trade
    Last Post: 16-10-2007, 10:50 AM
  5. Installing Strut Brace
    By Clay-VY in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-10-2007, 08:32 PM
