Page 1 of 2 12 LastLast
Results 1 to 25 of 31
Thread: back firing
    V.Y SS Commodore 5.7 6 speed manual Cammed
    Aug 2011
    Whyalla S.A
    Default back firing
    Well as the title states my ss is back firing.. i have noticed it happening around 1500 revs in 4th gear but its not consistent as it will do it once and a while so im asking if anyone else has had this problem and can shed some light as how to fix it..
    I have done the following:
    changed leads
    changed spark plugs ( bought 4 electrode bosch platnium plugs)
    im getting a fuel pressure and flow test done on friday and getting the fuel filter checked/ replaced if required
    i have been told that my o2 sensors are fine
    any other things to check
    im going to a second mechanic today to get another diagnostics test to see wat error codes come up, but all i can say is it is starting to annoy the f*%k out of me
    VY S3 V8 Monaro
    Jun 2005
    what's the spark plug gap of the new plugs?
    are you running on LPG or petrol?
    might also be worn ignition module(s)... :\
    let us know how u go!
    CAMMED VY SS Series 2 M6
    Jan 2009
    Whyalla S.A
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Back firing is over fuelling, which usually means a miss. The coils can die, is it missing at idle or just when cruising?
    Visit my Facebook page
    Jan 2009
    Whyalla S.A
    Just at cruising and my coils are working properly and my injectors are fine
    Jan 2009
    Whyalla S.A
    Jan 2009
    Whyalla S.A
    Well had a pressure and flow test done and everything is like brand new changed the fuel filter but its still back firing and not running right
    Aug 2011
    Whyalla S.A
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Check the plugs again, it isn't uncommon to crack one when putting them in. The old ones could have been failing anyway when you changed them.
    Jan 2009
    Whyalla S.A
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    They can still crack.
    VY Berlina V6 / R31 Skyline
    Dec 2008
    They need so little tightening, maybe it was 22mm last time I did plugs? Use a torque wrench to ensure you don't over tighten.
    Quote Originally Posted by xVisions View Post
    driving without a license at the moment, My vl has beaten every single car I've street raced!!
    Jan 2009
    Whyalla S.A
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Quote Originally Posted by sweefu View Post
    No, they are 5/8".
    All it takes is the plug socket to be on a bit of an angle and when you do the final tighten, it can crack the ceramic.
    Other than that, you may have a faulty plug.
  15. #15
    Aug 2011
    Whyalla S.A
    well this morning i got a check engine warning and my traction control turned off and wouldnt let me turn it back on? any ideas why this has happened
  16. #16
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Could be unrelated, may be a faulty wheel sensor. But if the car is missing and back firing, it could be causing it.
  17. #17
    Aug 2011
    Whyalla S.A
  18. #18
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    A cracked or faulty spark plug?
  19. #19
    Aug 2011
    Whyalla S.A
  20. #20
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    No. But since the engine light has come on, it should have set a code, so that may tell you what that problem is.
  21. #21
    Aug 2011
    Whyalla S.A
    sweet getting another scan done at 3 does it have to be a tech 2 scan tool or any will let me no
  22. #22
    Aug 2011
    Whyalla S.A
    well i have tried everything so all i can think is maybe my tune has gone up the shitter
  23. #23
    vy
    Jan 2012
    brisbane
    mate i had the same problem but in my s pac.. u said u got new leads.. take the silver metal cap with the spring on it of all the leads that connect to the plugs they can pop the lead off the plug if that dosnt work take the leads off at the coils nd check that the connection inside the leads is nice nd tight.. u said ur coils wer fine how did u check this??? also a trick i learnt from a friend hold ur mod nd set button turn ur key 3 times as far as u can before turning the engine on.. this will bring up another set of options and also any error codes that u can google.. btw if u change ur plugs so all 8 not just 4 keep everything the same... hope u find ur problem mate
  24. #24
    Jan 2009
    Whyalla S.A
  25. #25
    Jan 2009
    Whyalla S.A
    Took the silver caps of the leads and still the same and there no error code withthe mode and set buttons being held and wat do u mean inside the leads how do u check that
  1. '95 VS V6 back firing on LPG and missing on petrol.
    By pjdm1980 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-11-2011, 03:08 AM
  2. VS Ecotec, miss firing, back firing in the engine, surging of power. **Searched**
    By seq4x4 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-07-2011, 07:15 PM
  3. VS sII 1997 with lpg and petrol having some trouble with car back firing
    By milesgt in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-12-2010, 12:35 PM
  4. back firing through the carby on gas
    By dougs in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-04-2006, 02:09 PM
  5. back firing throuht the air intake
    By heberboy in forum VL Holden Commodore (1986 - 1988)
    Last Post: 20-06-2005, 09:25 PM
