Results 1 to 14 of 14
Thread: Purge hose help please!!
    vy fagon, ve ssv, vr BT1
    Dec 2011
    hood
    Question Purge hose help please!!
    Hey guys, got a Vy wagon on dual fuel the other day
    Was running rough since I got her. Have changed plugs
    Leads, cleaned MAF, changed TPS and IAC
    Along with cleaning throttle body in the process
    To find the bottom hose (I believe thus is the purge
    Hose) to be around 30cm connected to nothing!!
    Now I can't even tell where it came from! I'm assuming
    This is the cause of my rough idle/ wanting to stall
    At the lights. Can someone please help??
    Where do I get a new hose from and where fo I connect it
    From throttle body to where??
    WL Caprice
    Mar 2011
    Any pics of where it is? May help with diagnosis. Any other cars you can compare with?
    Dec 2011
    hood
    not sure if thoes pics worked. i have a vr wich is no real help. saw another thread saying the other end (not throttle body end) is at the back of the intake manifold?
    had a look hard to see anything but i didnt find where is should go
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    its behind the intake manifold, there should be a cluster of other vacuum hoses that plug into the same area
    Spoken by a true member of The Committee
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    replace the hose with a single piece of fuel hose running from the throttle body port to the purge valve port bolted to the rear of the manifold on the drivers side . what gap did you set the spark plugs to ?
    Dec 2011
    hood
    Quote Originally Posted by richardpalinkas View Post
    Thanks mate, I had a look but it was tight behind the intake manifold and couldn't see any other vacuum hoses back there Exept a smaller hose Wich looked as tho it had a in line filter on it I'm guessing I'm
    Looking in the wrong spot! And ideas?
    Dec 2011
    hood
    Quote Originally Posted by strgas View Post
    Thanks mate I will get some hose after work and try my luck. Is that the exact location of the purge hose? Back of
    Manifold drivers side?? Pretty sure there 1.5 it was whatever the NGK book sayed at repco
    May 2009
    Gold Coast
    It's hard to see, but if you keep looking there you will see it. It's a fixed length so it can only be somewhere it can reach
    May 2009
    Gold Coast
    Looking at an ecotec now, behind the drivers side rocker cover is a black box with an electrical plug, that's where the purge hose connects to, there should be 2 hoses there
    Dec 2011
    hood
    Found it thanks heaps mate! Plugged it back
    In only to start the car again is running better but
    Still has a rough idle sounds like it's missing from
    The exhaust. Shattered and out if ideas! Thanks
    Again for your help mate your a champion. Any other
    Ideas as to what it could be?
    strgas's Avatar
    Oct 2009
    I would recommend that you regap the plugs to .9 - 1.0 mm and using BP7EFS to reduce back firing
    VY 03
    Aug 2005
    I bought njk plugs that were meant to be 1.5 had problems with idle/miss and found that one was 1.3 Pretty sure they all have to be 1.5 gap
    May 2009
    Gold Coast
    Have you done spark plug leads? When I had my vx, I know I had a miss at wot only from standstill, it was leads, also had a big miss which was the dfi module directly under the coil packs. Just sorce them from a wrecker if you want to save a bit of $$$
    Dec 2011
    hood
    Yeh already did the leads didn't really change anything. Also changed the coil packs even tho the original ones seemed to have the correct resistance between terminals! Will try the DFI modul cheers for that!
    It was also pointed out that injector under throttle
    Body seemed to be leaking petrol (only a tiny bit) you think that could have anything to do with the rough idle?!?
    Thanks again bud!
  1. Replaceing purge hose
    By apathy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-08-2010, 01:32 AM
  2. Purge Hose help
    By jluda2099 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-09-2009, 04:04 PM
  3. Purge hose connection
    By gjvz in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 13-07-2009, 10:13 AM
  4. Fixed Purge Hose, Now Stalling?
    By 003KWK in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-03-2009, 04:18 PM
