Hi All
I have a 2003 Vy ss auto..The gearbox seems to be a bit slow to change from 1st to 2nd but doesn't seem to slip..The car has only done 74k.The other gears change up fine..I have heard of modifications available to speed up the changes..Anyone have any ideas or suggestions....Hope im not up for a new box
Thanks
Alan
Try and solve the problem as to why its changing slow before asking the box to perform harder by using something like a shift kit.
When was the last time it had an oil change?
Ronald Reagan (1986)
Dont think the car has had the auto fluid changed....At what k's should it be done?
Every 20-30,000km wouldn't hurt. You can go longer but I wouldn't.
I'd bet that the shifts will improve with a decent oil change.
If your good with a spanner, a 4L60E oil change is pretty straight-forward and the kits and oil can be bought in many places, otherwise you shouldn't pay more than $150 for a gearbox joint to do it.
Thanks for your advice....will get the oil/filter replaced and see how it goes
alan
Check the oil level too , & its a good idea to install a transmission oil cooler kit too . Heat kills Auto Trannies....
