Results 1 to 3 of 3
Thread: vy brake upgrade
    vy ss ute
    Dec 2011
    Kogarah
    Default vy brake upgrade
    hey looking at a brake upgrade for my vy ss ute ive got standard brakes with slotted rotors put they dont have the power id like and they fade and warp really fast just wondering if anyone heres done a brake upgrade for track as im looking to do 3 lap sprints and my brakes wouldnt last a lap. my brothers got an evo that he races and he says he wouldnt go any less than 4 piston at the front and 2 at the back with at least 330mm of width. however i found these on ebay what are your thoughts? 343mm PK1 COMMODORE VR-VZ BIG BRAKE KIT HSV SIZE PBR | eBay
    cheers.
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    Your brother is right go for a new or second hand HSV AP set up as minimum, 4piston 350mm front and 4 piston 332mm rears.
    That Ebay kit is ok for the street and will fill up big diameter wheels good but won't be too good on the track as the 2/1 piston calipers will let you down as they will flex as they get hot.
    A second hand AP VX-VY2 GTS setup would be better, 6 piston 362mm front, 4 piston 350mm rears (not sure on the rear size but pretty close).
    There is a 4 piston AP setup on ebay now:
    http://www.ebay.com.au/sch/i.html?_t...4.l1581&_pgn=5
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
    Jezza's Avatar
    Jezza is offline Ecotec Just Kicked In!
    VYII Acclaim
    Apr 2009
    South Australia
    check out GSL Motorsport in the sponsor section GSL RallySport and tell him what sort of brakes you need and what sort of driving there needed for and he can get you a good deal on some good brakes
    Quote Originally Posted by SHEENY05 View Post
    I have always thought a quick six will turn more heads cause if you gear a V8 you sorta expect it to go hard
  1. Brake upgrade kit - missing bolts!?!? (RDA VE upgrade for VS SS)
    By gsxr6000 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-04-2011, 10:35 AM
  2. [QLD] 290mm brake rotors Brake upgrade for VN/VP
    By mistergTRx in forum Parts And Other Items For Sale
    Last Post: 28-11-2010, 12:04 PM
  3. VT BRAKE UPGRADE - looking for brake line adaptors for vh to vt
    By rusty05 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 31-12-2009, 02:54 PM
  4. Spongy Brake Pedal after VT Brake Upgrade
    By DJ Ice in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-01-2008, 08:48 PM
  5. Vt Brake Upgrade
    By clinker42 in forum General
    Last Post: 04-04-2005, 08:32 PM
