Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By VYMAD
Thread: Vibration over 100 KMPH
    VY 5.7
    Dec 2011
    Jubail
    Default Vibration over 100 KMPH
    Dears,
    I am feeling very strange issues these days. Whenever the Car speed exceeds 100 KPH, the vehicle starts to vibrate vigorously. Up to 80KPH, things are cool.
    Any pointers, I have already checked the alignment ans tires and they are OK.
    Thanks
    Verynice's Avatar
    Verynice is offline Band
    VS Caprice 5L
    Aug 2008
    SA - The Backwards State
    VY Berlina V6 / R31 Skyline
    Dec 2008
    Checked your front rotors for warping or uneven wear? Front suspension, castor bushes? Steering rack?
    Quote Originally Posted by xVisions View Post
    driving without a license at the moment, My vl has beaten every single car I've street raced!!
    Jan 2008
    NSW
    Before you spend any money check your tyres. Alternate your spare between all 4 and take it for a drive.
    This happened to me once. I found out which tyre it was and replaced it.
    VY Executive S2
    Jan 2010
    VY 5.7
    Dec 2011
    Jubail
    Thanks for the valuable comments. Can I swap the tires i.e., swap front and back tires on alternate position ?
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Quote Originally Posted by vikki2sharp View Post
    If they're directional then you'll have to keep them on the same side, as in driver's side front to driver's side back.
    If not directional, then you can rotate them, as in driver's side front to pasenger's side rear. This is the best option, if they're not directional tyres.
    VY 5.7
    Dec 2011
    Jubail
    Well I had to change one tire, all tire balancing and final alignment and things are great .. Thanks for the comments
    Though I do feel steering vibration when I apply brakes, specially at high speeds
    VY II S V6 Supercharged and 911 Porsche 996 3.6
    May 2009
    VIC / NSW
    The vibration on braking is brake shudder which is frequently caused by brake disc thickness variation. A pretty common issue. Next time you replace the brake pads ensure the brake discs are machined or preferably replace them with new items. New discs for Commodores are not expensive but will be necessary if machining the old discs would result in less than minimum disc thickness being retained. (Given the minor difference in price between machining and replacing a disc here you might just as well fit new ones.) Fitting of the brake disc must be perfect otherwise the brake shudder problem will recur eventually as the brake pad contact area on the disc surface wears.
    There is much technical information available on this subject. Here is just one you may like to read as a guide.
    Common Brake Disc Information TB 01
  1. vibration in my vp PLEASE HELP
    By codicave in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-03-2011, 12:08 AM
  2. ve ss vibration
    By plasmid2 in forum VE Holden Commodore (2006 - ?)
    Last Post: 04-03-2011, 10:08 PM
  3. Vibration
    By VPV6BT1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-05-2010, 12:46 AM
  4. Vibration
    By ads1972 in forum VE Holden Commodore (2006 - ?)
    Last Post: 27-03-2010, 07:23 AM
  5. revs at 100 kmph
    By ford fan in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 24-06-2006, 11:46 PM
