Results 1 to 11 of 11
Thread: Urgent help please!!
    vy executive s2
    Jul 2008
    Default Urgent help please!!
    Put new SL shocks an springs in my car yesterday then today I was looking at the car and on the drivers side the wheel is very close to the wheel arch like I'll need to roll the guards yet on the passenger side there's heaps of room between the side of the wheel an the arch almost like the wheels are offset to the car !
    Anyone had this happen or able to tell me what could be the cause ?
    CAM'S VY PHREDDIFIED AND LEATHERED!
    http://forums.justcommodores.com.au/...w-leather.html
    vy executive s2
    Jul 2008
    VY S/II S Pack
    Apr 2011
    Mine is out like this too, I believe a simple wheel alignment will fix it.
    vy executive s2
    Jul 2008
    Yea I'm hopping that trying to get it in tomorrow for one I just wanted to make sure it wasn't anything crazy dangerous that I shouldn't be driving on
    VY S/II S Pack
    Apr 2011
    Just don't take corners too quickly/go over bumps too quickly so that the wheel doesn't move into the guard and you're fine.
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    The only adjustment a wheel alignment will do on the rear is toe which wont change the gap, only the angle the front of the tyre points to.
    With IRS the wheels should be the same distance from the guards as the diff is mounted to the body of the car. In the older cars with live axle the diff could be off centre which would cause this problem.
    Not sure why yours would be like this. Have you made sure the shaft hasnt popped out of the diff?
    Silver Certified.
    vy executive s2
    Jul 2008
    I'm fairly certain I didn't do anything crazy in the back end when taking the springs out.
    I took the shocks out an supported the hub with a jack an hit the old springs with the grinder. The new ones popped straight in bolted the shocks in an lowered the car.
    There's a mechanic around the corner from work might them to have a quick look
    one_and_only2004's Avatar
    one_and_only2004 is online now Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    This is a common thing - the suspension cradle in the back is a bit out of alignment that's all. A mate of mine on ProUtes had the same problem with his, and mine had the same problem (by about 10mm)
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
    vy executive s2
    Jul 2008
    Quote Originally Posted by one_and_only2004 View Post
    Ahh ok what do I need to do to fix it ??
    Mar 2008
    I didn't bother with mine, I'm pretty sure it's a matter of loosening the entire rear suspension assembly and re-setting it to the center.
    vy executive s2
    Jul 2008
    Ok thanks I'll still get the mechanic to double check it for me an get an alignment done
  1. URGENT New Manual conversion! URGENT
    By DevilDRake in forum General Discussion
    Last Post: 26-11-2011, 08:01 PM
  2. !!URGENT!! VY SV8 Transmission Problem !!URGENT!!
    By Coxy92 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 26-11-2011, 07:20 PM
  3. *URGENT* VS V8 coughin fartin splutterin, occasionally stallin *URGENT*
    By holden_1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-08-2010, 05:08 PM
  4. Please Help URGENT!
    By VTdriver99 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-07-2010, 07:13 PM
  5. URGENT URGENT alternator wiring
    By Keesh in forum Electrical Wiring / Questions
    Last Post: 19-09-2008, 01:10 AM
