Im looking at a VZ steering wheel on ebay and on the listing it says will only suit VZ, not a VY...
i thought all vz/y wheels were interchangeable?
will it fit?
Its been covered a couple of weeks ago (still actually on this page - 2nd from the bottom - VZ Steering wheel fit VY s2? ) but yeh, it appears it will.
Ive swapped my VZ HBD wheel with my WK Statesman (same as a VY wheel) and it went on without any issue. Might be that its a HBD wheel, but it was designated for VZ.
Going the other way VY->VZ was a tad tricky as the back of the wheel where the shaft sits needs to be ground down about 3 or 4 mm.
But from all accounts VZ-VY = no worries.
As long as the rear of the steering wheel hub , engages the clockspring without any force you are sailing!! , some may need to be ground down depending on what clockspring you have ... the VZ clockspring with the illuminated radio controls is different , your VY wheel will have to be ground off a little to fit it.
