Results 1 to 7 of 7
Thread: Loud clunking
    VX Acclaim S2
    Dec 2008
    Question Loud clunking
    Have a VY Berlina wagon v6.
    We were cruising around town tonight and noticed a bloody horrible loud clunking noise. Sounded like metal on metal.
    Coming from the rear left, was only audible with foot off decelerating up to an intersection or just cruising in to stop.
    Clunking goes in time with the wheels so as we slow down the clunking gets slower etc.
    Had a look underneath for anything obvious but came away scratching my head.
    Just wondered if anyone else had the problem before i fire it into the mechanic.
    VH SL/E...'09 dual cab 4X4 hilux
    Mar 2011
    roxby downs
    center bearing on the tail shaft
    rubber couplings on the tailshaft
    one of the drive shaft cv joints
    check oil in the diff
    If in doubt......FLOOR IT!!!
    vy one tonner v8
    Apr 2011
    gold coast
    hey i think i have the same sort of sound, i cant work it out it is heard when i take off from stand still, and some times when i let the clutch out or even let the foot of accelarater, and some times makes a clunk at low speed when i turn a corner, but cant hear any noises at high speed. i might look into those suggestions that were mentioned.
    let my know if u have any luck finding the problem
    '03 VY II V6 Manual Ute
    Nov 2011
    Quinns Rocks Perth WA
    Sounds like a flywheel. Same problem in mine... If its dual mass then it's ready for the bin. Where as a solid mass may possibly be machined..
    Nov 2011
    Is it a constant clunk clunk clunk or do u only get it once every time the car let's off the accelerator at low speeds?
    vy II calais
    Jul 2010
    Mildura Vic
    my ute used to do the same thing. you would be driving along and back of the throttle and it would clunk. it felt like the tailshaft to me. so i ended up replacing the centre bearing and the tailshaft and it fixed the problem
    VZ SV6
    Jan 2012
    newcastle
    Hi
    yer I have a vz doing the same thing
    I am going with the centre bearingbecause when it clungs as you say sounds like its hitting the floor
  1. Loud clunking noise from rear wheels comes and goes.
    By karenlh in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 25-12-2011, 03:01 PM
  2. VS fe2 front left loud clunking
    By VS excop v8 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-03-2010, 06:31 PM
  3. Loud Clunking/Grinding
    By jamiev90 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-06-2009, 09:13 PM
  4. Clunking, anybody help?
    By padrickz88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-11-2008, 05:21 PM
  5. Clunking
    By Noy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-03-2007, 05:06 PM
