Results 1 to 6 of 6
Thread: swapping clusters in vy execs
    88 VL Turbo SL and 86 VL SL
    May 2010
    VIC
    Lightbulb swapping clusters in vy execs
    hi can you swap your povo pack vy exec cluster to something more better looking like vy ss,berlina,calais,clubsport.
    i know the berlina,calais,clubsport are three lcd screen will they work or not ?
    Modifying a car is like a drug once you start you cannot stop
    Holdens if your not in one your behind one
    kcpwns's Avatar
    kcpwns is offline Kicker - Livin' Loud :)
    VY V6 Equipe
    Jan 2010
    Shepparton
    As long as its the same series. I swapped mine for a Calais and it worked fine. You will get the srs warning light though.
    Quote Originally Posted by some_guy View Post
    This posts stupidity makes baby jesus cry.
    My Ride
    currently retrofitting projector headlights
    kcpwns's Avatar
    VY V6 Equipe
    Jan 2010
    Shepparton
    Oh and the same cylinders
    My Ride
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    been covered multiple times on this forum
    - as long as its from a VY. From memory VY=grey plug VZ=blue plug (or vice versa). Clusters physically the same but the plugs arent
    - if its from an 8 into a 6 or vice versa need to have some settings changed via Tech 2 because the fuel guage will read upside down
    - Tech 2 is needed to adjust the speedo to cater for different diff ratio from 8 to 6 and sometimes from Calais to Exec etc (as they have different ratios)
    - 3 panel will work as well
    So yes, will work BUT you cant just change them over and hope for the best! It will work to some degee, just not perfectly.
    HamaTime™'s Avatar
    HamaTime™ is offline VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    HSV gear stays in HSV's
    sorry.
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
    VE SSV MY10
    Jun 2006
    vy series 1 and vy series 2 are differant make sure u keep them from the same series thats what causes the fuel gauge to read backwards and the rest will need tech 2 to change the no of airbags and tacho if from v8 and diff ratio for speed
  1. Holden Execs to take pay cut
    By Rufus® in forum The Pub
    Last Post: 12-03-2009, 06:09 PM
  2. swapping clusters
    By MiSs MeOw in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-04-2007, 04:11 PM
  3. How much are V8 VY execs going for if I can find one?
    By muso in forum VY Holden Commodore (2002 - 2004)
    Last Post: 26-09-2006, 07:45 PM
  4. Swapping clusters on VY
    By Wagone in forum Electrical Wiring / Questions
    Last Post: 12-09-2006, 11:23 PM
  5. Swapping clusters
    By furrhead in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-06-2005, 11:16 PM
