Results 1 to 6 of 6
Thread: Help with sub power cable
    VY Berlina
    Nov 2011
    Default Help with sub power cable
    Not sure if this is in the right section but, I need help running the cable for my subwoofer from the battery terminal and somehow getting it inside the car.
    I have an auto VY Berlina, would I need to make a hole in the firewall (i think that's what it's called) to make the cable come through the car?
    kcpwns's Avatar
    kcpwns is offline Kicker - Livin' Loud :)
    VY V6 Equipe
    Jan 2010
    Shepparton
    There should be a blank spot for the clutch or whatever. Smash it through there
    Quote Originally Posted by some_guy View Post
    This posts stupidity makes baby jesus cry.
    My Ride
    currently retrofitting projector headlights
    1998 Mercedes Vito 113
    Oct 2009
    S.E VIC
    ^ as above, in the middle behind your left extractor/header (looking at the front of the car) there's a rubber grommet about 3-4cm's long and 2-3cm's wide. Just unplug it and take it out, and make a hole through it and run the wire through.
    edit: you can also run it in through the big rubber grommet in the back left corner, just unplug it a bit and feed it through the top.
    Quote Originally Posted by perkoracin
    it like u pull at to a red light and they go o its that fag from just Commodores and it like u go tohe drags and ur car runs a like a 9 sec run as a eg and theres run a low 14 um i would Lol so hard like Epicly and then call them The Internet Mouthers and no go Lol thats a eg they might have Fast as rides 2 but may not sound as a Nice small block chevy with a Supercharger on it lol.
    Click here for my old VY Commodore!
    hakhawk's Avatar
    hakhawk is online now smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    Quote Originally Posted by DevilDRake View Post
    through the top? so the positive power wire is resting against a metal edge, which will eventually rub through, causing a blown fuse, or at worst a fire... sounds good.
    i use the grommet behind the drivers strut tower, if you look from inside the car, theres 4 cavities in the grommet surrounding the main bundle of wires. go through one of them and you'll be fine.
    you can use the clutch grommet, but i find it to be more work, and extra wire used.
    Oct 2009
    S.E VIC
    Quote Originally Posted by hakhawk View Post
    Well i didn't know into explicit detail, I was just telling him where it is.
    I've got mine foamed on the edges, and the grommet has been cut out to feed the wire straight through.
    vt s pack
    Oct 2010
    brisbane
    looking from the front back, right side- not drivers
    behind the strut tower theres a blank space if ur cars manual and cant use the clutch spot
  1. Splice a usb cable to ciggie lighter power cable
    By dmo89 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-05-2011, 03:44 PM
  2. where to run a power cable
    By nicklong1993 in forum Car Audio
    Last Post: 24-12-2010, 01:48 PM
  3. power cable
    By markvr in forum Car Audio
    Last Post: 15-05-2009, 08:28 PM
  4. vs amp power cable
    By jfresh in forum Car Audio
    Last Post: 24-03-2008, 02:23 PM
