Results 1 to 3 of 3
Thread: Vy tail lights
    1998 Mercedes Vito 113
    Oct 2009
    S.E VIC
    Default Vy tail lights
    Hey guys,
    I've had a little search but mine seems to be doing the opposite.
    My right tail light doesn't work but when i press the brake it works. I thought it may be because of a dual filment bulb (which may be true until i get another globe tomorrow) but sometimes when it's not working i can hit the tailight and the bulb works.. Could that be more of a wiring thing or still the globe?
    Cheers.
    Quote Originally Posted by perkoracin
    it like u pull at to a red light and they go o its that fag from just Commodores and it like u go tohe drags and ur car runs a like a 9 sec run as a eg and theres run a low 14 um i would Lol so hard like Epicly and then call them The Internet Mouthers and no go Lol thats a eg they might have Fast as rides 2 but may not sound as a Nice small block chevy with a Supercharger on it lol.
    Click here for my old VY Commodore!
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    The globe is loose in its socket or there is corrosion present. Pull the light assembly out, remove the globe and check to see that it is clean on the metal section without corrosion. Check inside the socket for the same thing. Replace the globe and have someone operate the brake pedal, while you wiggle the globe. If it works intermittently, the spring contact at the bottom of the socket needs to be pulled up slightly to increase tension and provide a better connection.
    Oct 2009
    S.E VIC
    I took it apart quickly and wiggled the wires around. I'll go further when i get my new bulb.
    Cheers.
  1. [NSW] [FS] Black GTO Monaro HSV Tail Lights GENUINE NOT ALTEZZA OR MARS LIGHTS
    By RvtRvx in forum Parts And Other Items For Sale
    Last Post: 07-09-2011, 12:33 PM
  2. Lost all my interior lights, head and tail lights
    By b.e.a.s.t. in forum Electrical Wiring / Questions
    Last Post: 06-02-2011, 02:09 PM
  3. [VIC] rims, VL&VK tinted tail lights, VK calais tail lights, springs and more... :)
    By vk.jonno in forum Parts And Other Items For Sale
    Last Post: 02-10-2010, 09:12 PM
  4. thinking about buying tail lights and or head lights for my VX SERIES 2
    By Silenced in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-01-2010, 09:07 PM
  5. [SA] Vs Tail lights & Tinted Vp rear tail lights and garnish
    By hothousevn in forum Parts And Other Items For Sale
    Last Post: 23-10-2007, 01:46 AM
