the valcro i used for the dash mat melted from the heat and does anyone know how to remove it??
this is what it looks like
thanks.
Ouch. I'm not to sure but I would probably try some dash protector/cleaner first and if all fails some WD40 (has removed many marks for me without any harm).
A.MILMO
Looks like melted glue residue from the photos.
I would try ACETONE. You can buy this at Bunnings for about $9. Open the door and try it on the dash material that is covered by the door when closed to ensure that the plastic does not mark or dull after the acentone is applied and dried. (It should be ok as I tried it on mine). Use a white cloth otherwise you risk bleeding colour into the plastic which will never come out.
Commercial auto Dashboard treatments will be unlikely to remove the material. You will most likely just get a shiny dash and the residue may be even more prominent.
i ended up getting it out, took alot of scubbing and then mr sheens fixed it up.
thanks guys
Next time for anything sticky try using "orange cleaner" their available at Woolworths here in WA or Safeway over east
Orange cleaner is good. For adhesive removal I use the 3m branded adhesive removal spray works awesome.
lucky you got it now i had it on my old ute and it looked like it had been baked on there for years never came out fully
