Results 1 to 10 of 10
Thread: "Check Engine" indication coming and going
    VY 5.7
    Dec 2011
    Jubail
    Default "Check Engine" indication coming and going
    Dears,
    Happy New Year to everyone.
    I am having a problem, I am getting "Check Engine" error repeatedly, though it will not stay permanently. It disappears after sometime, but it is occurring repeated.
    Is it possible to check the error cause if there is no indication available, any possible pointers ?
    scvs6's Avatar
    scvs6 is offline Donating Member
    1995 Holden VS Berlina 3.8L Supercharged V6 L67
    May 2011
    Ballarat, VIC
    Hi mate,
    If it's the 5.7L Gen III V8 then my guess is it is going to be the Oil Pressure Switch. They are a common problem with those engines and make the check engine light come on.
    But get the codes checked first incase that isn't the problem.
    Quote Originally Posted by Jasper44
    For all you kids out there, when your about to have sex, just remember that it would be better if you went out and shot a police officer with a bazooka instead.
    Including car parts (VS, VT, VX, VY, WH etc), my WH Statesman, and other things listed on eBay.
    VY 5.7
    Dec 2011
    Jubail
    Yea, its the same one, but oil pump was changed just last month.
    I will get the codes checked to be sure ... thanks a lot
    scvs6's Avatar
    May 2011
    Ballarat, VIC
    Quote Originally Posted by vikki2sharp View Post
    No problem, but I didn't say oil pump. The Oil Pressure Switch is separate. It is located right at the back of the engine, not hard to change though.
    VZ SSZ
    Nov 2011
    Western Australia, Perth
    I actually have the same problem with my VY 5.7L aswell. When the check engine signal appears is it a picture of an engine or is it in writing?
    VY 5.7
    Dec 2011
    Jubail
    VY 5.7
    Dec 2011
    Jubail
    CAMMED VY SS Series 2 M6
    Jan 2009
    Whyalla S.A
    2003 VY SS
    Jan 2012
    Just had mine VY SS fixed, was as simple as a split hose. 20 bucks for a new hose about 5cm long hahaha
    The split hose was playing around with the oil pressure senser, which was playing with the fuel mixtures to make my car run to lean.
    I got the hose fixed, put it on the dyno and edited the fuel mixtures to run as they suppose to.
    Now its like a new car!!!
    vy
    Dec 2010
    brisbane
    Default radiator
    I had this occuring prob in my vy.my mechanic at the time said it was the o2 sensor which they changed but it kept happening.turns out after getting this car serviced for over three years they had never changed or checked the state of the radiator coolant.Heads cracked....
  1. Throttle position sensor setting off "Check Engine" warning
    By Calaber in forum VE Holden Commodore (2006 - ?)
    Last Post: 21-11-2011, 02:16 PM
  2. Auto box noises coming through floor when lever in "2" - something touching???
    By Circlotron in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-09-2011, 10:51 AM
  3. ss "check engine"
    By maka5 in forum VE Holden Commodore (2006 - ?)
    Last Post: 07-02-2011, 10:48 PM
  4. "check engine" light problem...VR Wagon Eclipse
    By sam_drury in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-03-2010, 03:16 PM
  5. Is the warning "service engine oil" the same as "check oil" ?
    By morris in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 04-12-2006, 04:36 PM
