Results 1 to 12 of 12
Thread: how much power steering fluid a vy commodore hold
    VY Lumina
    Jun 2011
    adelaide
    Default how much power steering fluid a vy commodore hold
    ok so the shudder is pi$$ing me off ive talked to holden they said that my car has been done.. so im betting the car yard i got the car from 6 months ago put some $hit stuff in since it has got louder and louder the longer ive had the car.. so i need to know how much nulon ill need to buy... supercheap have 500ml bottles with 15% off atm...
    thank you guys oh if the usage of the $ is a problem ill remove on request
    aaronevolution's Avatar
    aaronevolution is offline Donating Member
    TURISMO VZ SS 6.0
    Mar 2011
    Hastings, Victoria
    Quote Originally Posted by Ozzy View Post
    If you have the manual that comes with the car the correct amount should be in there somewhere.
    Don't just top it up, drain it out and refill it.
    VY Lumina
    Jun 2011
    adelaide
    ah right ill have to check it out... yeah not topping it up there is no point the shudder would still be there
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Shudder will most likely be there with new fluid too.
    Rack or pump is gone Im guessing.
    Silver Certified.
    VY Lumina
    Jun 2011
    adelaide
    Quote Originally Posted by aaronevolution View Post
    i looked and looked i couldn’t find the correct amount
    Quote Originally Posted by RiCeY View Post
    I’m not sure about that.. the power steering is fine with anything over 10 km/h with no sound
    1998 Mercedes Vito 113
    Oct 2009
    S.E VIC
    I know the VY's had to common fault with full lock shuddering..
    I'm going to say it's probably your steering rack. Very common, even if already fixed.
    Quote Originally Posted by perkoracin
    it like u pull at to a red light and they go o its that fag from just Commodores and it like u go tohe drags and ur car runs a like a 9 sec run as a eg and theres run a low 14 um i would Lol so hard like Epicly and then call them The Internet Mouthers and no go Lol thats a eg they might have Fast as rides 2 but may not sound as a Nice small block chevy with a Supercharger on it lol.
    Click here for my old VY Commodore!
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Power steering isnt under as much load once moving so issues with pressure arent as obvious.
    Silver Certified.
    vpcalais6's Avatar
    vpcalais6 is offline F#%ING [P] PLATER
    V6 manual vp Calais
    Sep 2007
    central coast
    Make sure you bleed the system once refilled
    CHEV badges Australia says no
    fighting online is like racing on a special olympic. Even if you were to Win! your still ####ing retarded
    Dec 2009
    If it's been "done" by Holden then it has the revised power steering hose that is routed behind the radiator and secured to the square section behind the bottom of the radiator. This was a revised hose to get rid of the shudder and was only fitted if the owner complained while the car was under warranty. Mechanic friends of mine said even with this hose VY's can still shudder. Hose and bolts etc costs about $150 from Holden. Mine doesn't have the revised hose and had shudder. I replaced the fluid a few times. I just used Castrol or Valvoline Dexron 3 and some Nulon additive. The shudder went away and I only noticed it after about 12 months so it probably needs new fluid again?
    The shudder does notr mean that either the rack or the pump are stuffed. From what I understand the rack was revised in the VY along with the front geometry, it's similar to the Monaro, this is why a VY steers and feels a lot different to a VT/VX to drive and they do not get shudder so I assume the revised rack doesn't match the pump properly and the issue is probably the pump is n't supplying enough pressure or fluid at idle speeds when parking the car etc.
    VY Lumina
    Jun 2011
    adelaide
    i think ill take a look at that and see... but if the fluid replace lasts about 12 months... im happy with that
    u dont know how much i need though do u?
    VY SS
    May 2011
    Auckland
    VY Lumina
    Jun 2011
    adelaide
    ok cool ty
  1. VR V6 93' Commodore ABS Pump/Power Steering Fluid leak etc'
    By MissL84 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-03-2011, 01:28 PM
  2. trans fluid and power steering fluid
    By jabba13 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-02-2011, 09:51 PM
  3. power steering fluid?
    By mattgreen in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-11-2010, 10:08 AM
  4. Power Steering Fluid
    By Mickyh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-12-2008, 05:38 AM
  5. Power Steering Fluid?
    By Cody in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-07-2005, 03:58 PM
